Old 01-26-2004, 01:02 PM   #1
solomrus
Member#: 1767
Default OBD1/1996 RA drive train?
ok, still learning about my type-ra drive train.
quick question for JDM folks.
from what i know (given, it isn't much) the early 1996 type-ra drivetrain in my car *should* be obd1.
which leads me to ask, is it possible that a US code scanner will be able to pull the MIL indicator codes from the JDM ecu?
if i were to make an assumption here, then it would be to assume that it ISN'T possible.
has anyone tried it? i want to see if it is possible before dropping cash on a useless tool.
thanks everyone.
--r
solomrus is offline   Reply With Quote
Old 01-26-2004, 01:19 PM   #2
EJ25
Member#: 10768
anything jdm < 2000 is odb1. If you put the ecu in diagnostics mode, it will flash the codes on the cel indicator. Pretty simple stuff.
EJ25 is offline   Reply With Quote
Old 01-26-2004, 02:10 PM   #3
solomrus
Member#: 1767
ok, good, this is what i am looking for.
what do you need to do to get it to flash codes?
flip the ignition on/off a few times or something? that is what i have done on my jeep, never done it on a scooby.
thanks in advance.
--r
Old 01-30-2004, 04:37 PM   #4
solomrus
Member#: 1767
ok, found what i needed to pull codes.
koeo codes are:
24 air control valve
33 vehicle speed sensor
we knew the speed sensor, and are taking steps to rectify.
speed sensor is in dash pod, requires a lead to ecu. not currently there. getting pinout to take care of this.
going to test air control valve this weekend, to see if it is out of range. should know tomorrow what is up with that.
--r
Old 01-30-2004, 04:45 PM   #5
spiralsmurf
Member#: 16085
2005 STi
when you say air control valve, you're referring to idle air control right?
spiralsmurf is offline   Reply With Quote
Old 01-30-2004, 04:47 PM   #6
solomrus
Member#: 1767
yes, that is affirmative.
--r
WTB STi drive train or RA gears flyingtaco SWIC Private Classifieds 2 10-08-2009 01:53 PM
WTT 6-speed drive train for 5-speed wrx drive train takeshi999 SCIC Private Classifieds 24 05-11-2008 08:46 PM
MY99RS drive train FS Joe Hogan Texas Impreza Club Forum -- TXIC 1 03-21-2001 07:55 AM
New Wrecked Impreza and Drive train pisc Greg555 Mid West Subaru Owners Club Forum -- MWSOC 12 01-19-2001 12:39 AM
Weird drive train noise, HELP!!!!!!! NYEJ25 Technical Forum Archive 5 08-31-2000 06:39 AM
