Old 01-26-2004, 01:08 PM   #1
Rossi
Member#: 37618
96 L
Red
Default Crankshaft position Sensor Malfunction
I have a 96 Impreza 1.8 L giving me a CEL P0335, "Crankshaft Position Sensor Circuit Malfunction". The car runs fine when it is going, but it has trouble trying to start. It turns over fine but nothing ignites. I was planning on just replacing the sensor myslef, but I am unaware of how complicated this procedure might be. If some one has done this before, could you please explain to me how to do it. If there is another option, please let me know, thanks.
-Rossi
Rossi is offline   Reply With Quote
Old 01-26-2004, 01:19 PM   #2
SubyTechMaster
Member#: 4423
'04 08 Tribeca, SVX
Gold, Maroon
If you take a look at your engine, directly above the Crank pulley and slightly behind the Timing belt cover (black plastic) you will see the Crank Sensor (brown plastic, held down by 10mm bolt head). Unplug connector, remove bolt, replace sensor.
SubyTechMaster is offline   Reply With Quote
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Engine Management & Tuning 2 07-05-2006 10:50 AM
Crankshaft Position Sensor Air Intake Temp Sensor CODES!! please Help!! GT40R Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-02-2006 05:07 PM
Crankshaft Position Sensor, Air Intake Temp Sensor CODES!! please Help!! GT40R Southern California Impreza Club Forum -- SCIC 2 07-01-2006 06:03 PM
p0336, Crankshaft Position sensor Circuit range/ Performance problem? Who has had it? eightballrj Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-28-2004 09:04 PM
