Old 01-26-2004, 01:28 PM   #1
wagon-wrx
Member#: 20643
2002 WRX wagon
Default Any issues with stock turbo/injectors with Walbro pump?
Hay all, I just wantted to ask if any one would think there would be any problems with doing the fuel pump first and hen doing injectors at a latter date? Working up to a VF34. I have Samcos, drop-in filter, up/down pipe, Cobb st2.
As I understand with my set-up now I could be overwhelming my stock pump at higher RPMs. Any coments would be great.
wagon-wrx is offline   Reply With Quote
Old 01-26-2004, 01:48 PM   #2
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The upgraded fuel pump will work fine with no other modifications.
As long as you do pump before injectors, and injectors before turbo, you're fine.
/Andrew
Kha0S is offline   Reply With Quote
Old 01-26-2004, 04:20 PM   #3
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
Cobb's VF3? setups are without fuel pump...so I did injectors before pump. But I probably will soon just for safety.
mexicanpizza is offline   Reply With Quote
Old 01-26-2004, 04:29 PM   #4
rogue
Super Moderator
Member#: 7977
100% Abuse
Yeah... injectors don't mean diddly if they don't have fuel to back it up
By the flip side of that coin... upgrading your fuel pump before your injectors is pretty meaningless too, from what I understand... stock fuel pump pushes fine to stock injectors.
Only really make sense to do both at once
rogue is offline   Reply With Quote
Old 01-26-2004, 04:51 PM   #5
Hit Man X
Member#: 27787
'02 WRX Sedan
Tossin in the larger F-pump isn't bad but just keeps the fuel flow there to the injectors. The stock injectors get taxed before the pump goes so, there's not a need to do one before the other really.
Hit Man X is offline   Reply With Quote
Old 01-26-2004, 05:11 PM   #6
wagon-wrx
Member#: 20643
2002 WRX wagon
Thanks for the replys, I did a search but could not find this exact question. I dont think I would want to do to much in one sitting, I think I can run the pump for a bit and make sure its working then do the injectors a week later make sure there working ETC...
I also am not sure if the Cobb st2 can is set to run STI pinks or if it will need a flash. I will have to give them a call or hit the Cobb forum.
Old 01-26-2004, 06:29 PM   #7
Mildmanneredman
Member#: 29962
I did mine a couple of weeks ago. Runs great, I even had mine IDC's drop a little.
Mildmanneredman is offline   Reply With Quote
Old 01-26-2004, 08:45 PM   #8
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
I'm running; VF34, walbropump, APS tmi, txs turbo-back, STOCK INJECTORS, and FPR MOD, UTEC in closed loop with stage four map. No knock,no issues, lots of power.
wrx plus is offline   Reply With Quote
Old 01-27-2004, 03:07 PM   #9
wrx plus
Member#: 42253
2003 RWD WRX
NJ: Stock Turbo, Injectors and Fuel pump I3oostedScooby Private 'For Sale' Classifieds 3 02-27-2006 05:06 PM
WRX stock turbo, injectors and fuel pump rossscarbro Private 'For Sale' Classifieds 15 06-08-2004 09:53 AM
