Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-26-2004, 02:42 PM   #1
Max Umbarger
Member#: 1112
2006 FXT
RBP
Default Any recipe for homemade water remover for gas?
Instead of using Heet i'm sure there is a cheaper way or even better way of removing water from gas. I know the main ingredient is Isopropyl Alcohol. I don't know if you can buy IPA off the shelf tho
Max
Max Umbarger is offline   Reply With Quote
Old 01-26-2004, 04:10 PM   #2
Karl
Member#: 13110
Rubbing alcohol you buy in pharmacy is 70%.
Unless you work in a lab, it's probably difficult to get ahold of pure stuff.
Why not just use Heet?
Karl is offline   Reply With Quote
Old 01-26-2004, 07:01 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Dood...ya can't cheap out here....this is your fuel system we're talkin' here....Jesus....spend 10 bux and do it right...
Old 01-26-2004, 08:18 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
or just crawl under your car with a torch and heat up the fuel tank until it all evaporates. Its cheaper........(depends on how much your life is worth)
Hawk296 is offline   Reply With Quote
Old 01-26-2004, 09:21 PM   #5
4npower
Member#: 9018
02 WRBP WRX
Slvr 06.5 Jeep Grnd SRT8
OK lets see DRYGAS and HEET are between $.99 and $2.99 spend the money.
4npower is offline   Reply With Quote
Old 01-27-2004, 12:58 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I think the gas would evaporate first. And, it costs more than drygas
Old 01-27-2004, 03:44 PM   #7
z&cobb
Member#: 12344
2002 2JC
blue
The Prestone stuff in the red bottle treats 24 gallons and both methanol and isopropanol are ingredients. It costs like 3.50 at Walmart. Worked on my wife's Odyssey when it sputtered badly.
z&cobb is offline   Reply With Quote
Old 01-27-2004, 10:37 PM   #8
Fermi
Member#: 50666
2000 Outback Sport
Blue Ridge Pearl/Titanium
I think I saw HEET for about $.80 at Wal-Mart. The Iso-HEET was about a dollar. Not too bad an expense to stick in your tank a few times each winter. Better and safer than trying to mix chemicals together yourself!
Fermi is offline   Reply With Quote
Old 01-27-2004, 10:41 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
YO----MAX......
Ya getting any of this.....????
Old 01-28-2004, 09:45 AM   #10
Max Umbarger
Member#: 1112
2006 FXT
RBP
Actually I just wanted to see if I couldn't get it in a larger container, so I could just put it in every night at home, and not have buy it every 2 days, I drive to school and it is a 40 mile drive times 2 equals 80miles, times 2 days equals 160miles and the my 11 Gallon gas tank is empty becuase the EJ18 don't get good mileage after 210,000 miles
Thanks for the info, but IPA is about 3.79 a gallon and heet is 4 bottle for 3.99
max
Old 01-28-2004, 10:44 AM   #11
Karl
Member#: 13110
Why do you have to put dry gas in your gasoline that often?
Old 01-28-2004, 11:29 AM   #12
LyveWRX
Member#: 19057
& Blue Ford & '72 CB350
In your case I would just use a pint or so of Technical grade methanol. Generally that will absorb any moisture and burn away...
nick
(you might be able to purchase through VWR lab supply....)
LyveWRX is offline   Reply With Quote
Old 01-28-2004, 10:40 PM   #13
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
You should not need to put that much in that often. I haven't used that stuff in years.
Mike Wevrick is offline   Reply With Quote
Old 01-29-2004, 05:53 AM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
Once a week would be overkill, and once a month would suffice I'm sure....
Anyone have a recipe for Homemade Calzones? Sharkbait Off-Topic 33 02-23-2007 01:50 PM
Pizza stones. What are they, and do they matter for homemade pizza? recipe ideas? plunk10 Off-Topic 39 12-21-2005 06:58 PM
Is it even worth it for Alcohol / Water Injection for a stock turbo?? Red Rexx Water/Methanol Injection, Nitrous & Intercooler Cooling 10 09-22-2005 03:29 PM
Any recipe for removing water from gas? Max Umbarger Normally Aspirated Powertrain 3 01-29-2004 05:13 PM
I need a water can for water injection, any ideas? AntiochCali Water/Methanol Injection, Nitrous & Intercooler Cooling 3 06-02-2003 10:57 AM
