Old 01-26-2004, 07:10 PM   #1
The Donnn
Member#: 33178
SQC 106
Default what size tire help me here ? 18x8.5 44et rims
exactally what the title says. these rims are going on my sti. what size tire can i run. the car is already lowered with sti pink springs. any help would be appreciated.
The Donnn is offline   Reply With Quote
Old 01-26-2004, 07:30 PM   #2
norseone
Member#: 16350
B8.5 Audi S4
235/40/18 AFAIK. Depends on the tire though. Some are wider, some are thinner.
And those wheels read like Volks?
norseone is offline   Reply With Quote
Old 01-26-2004, 09:28 PM   #3
The Donnn
Member#: 33178
SQC 106
haha, yes they do don't they
Old 01-26-2004, 11:53 PM   #4
olappa
Member#: 48126
2004 STi
blue/gold
Helllllooo Donnn! Whasap! Just recognized the triple N's and had to say hello bro. sorry I cant help you with that question.
See you around
Olappa
olappa is offline   Reply With Quote
Old 01-27-2004, 12:11 AM   #5
Sev
Member#: 8364
4.5 STi
dirty
235/40s droped on coilovers had to roll the rear fendors might b able to get away with just pinks
areg
Sev is offline   Reply With Quote
Old 01-27-2004, 09:02 AM   #6
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I would say 245/35-18. You may need to run about -2 degrees of camber to get the wheels to clear the fender in the back with that offset, but that's a good thing, camber is your friend.
Kevin
Red Rocket is offline   Reply With Quote
Old 01-27-2004, 02:39 PM   #7
The Donnn
Member#: 33178
SQC 106
yeah kevin thats what i was thinking also.... what up taha, hows everything man.
Old 02-01-2004, 01:14 AM   #8
The Donnn
Member#: 33178
SQC 106
bump, if this was posted somewhere already , please link
Old 02-02-2004, 12:11 AM   #9
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
I agree with Kevin, but there's not many reasonable tires available in that size. You might even be able to get away with just removing the rubber fender strip if you have rubbing issues.
rex n effect is offline   Reply With Quote
Old 02-02-2004, 08:40 AM   #10
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
Donn,
I just got my 18" SSR 18x8.5. Fitted them with 235/40-18's IMO you need to go wider, a 245/35-18 would be ideal but there is no such thing as an all season in that size that I can find. The 235's don't push past the lip of the tire - read: almost 0 protection for the rim.
Good luck finding them, You should have more than enough room for 245's from what I felt, I dunno about 255 though
-- Steve
SLKWrx is offline   Reply With Quote
Old 02-02-2004, 08:36 PM   #11
jreat
Member#: 22281
2002 WRX Impreza
Pearl Blue
so for 18" a good size would be 235/40 or 245/40 on a Sedan. How much could it be lowered?
jreat is offline   Reply With Quote
Old 02-03-2004, 08:57 AM   #12
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
245/35 is the best bet.. its actually perfect.. 235/40 is already oversized by about .5" and unless you're going with S-03's, there is almost 0 protection for the rim for curbing. 245/40 would just be too tall IMO. From what I see, you could lower a sedan about 1" with 245's.. 235's are no problem anywhere
-- Steve
Old 02-03-2004, 11:36 AM   #13
Chaste Automotive
Vendor
Member#: 44921
245/40 I have 18x8.5 44et volks and this has been the best set up, 235 is a little too small, you do not have enough tire. 245 40 is fine if you are going to drop to 35 then you can run 255/35 the. 245/40/18 will fit just fine, take itfrom someone that has the same size rims.
Chaste Automotive is offline   Reply With Quote
Old 02-03-2004, 12:19 PM   #14
tora
Member#: 5851
09 Forester XT
+ NA Miata
245/40 is ideal as Chaste has said, I've done two cars with the same size wheels and 245 was a better fit than 235.
tora is offline   Reply With Quote
Old 02-03-2004, 01:14 PM   #15
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
245/40 will be almost a full inch taller in overall diameter. Whether it works or not is one thing, but you're talking about almost a 2 mph difference in speedo. While that may not be significant to many, saying its ideal is incorrect
245/35 is ideal, 245/40 will work, but not correctly
-- Steve
Old 02-03-2004, 07:02 PM   #16
The Donnn
Member#: 33178
SQC 106
i am leaning towards245/35. these are for summer only/
Old 02-03-2004, 11:51 PM   #17
jreat
Member#: 22281
2002 WRX Impreza
Pearl Blue
I don't care if it throws the spedo off a little, but here in Mi. the roads are bad and it needs more protection than 35. So 245/40s would work then with lowering it with Eibachs, I think they are 1.4.
Old 02-04-2004, 01:27 AM   #18
rex n effect
Member#: 15289
02 wrx pollen silv
It's not just that the speedo will be off 5 mph at 100mph, but it will hurt your acceleration because you are changing the gearing. If you have bad roads, then why are you getting 18" wheels? You are also, in effect, raising the car by a half inch, hurting handling as well.
Old 02-04-2004, 02:05 AM   #19
Sev
Member#: 8364
4.5 STi
dirty
I have 1/8 inch clearence from the strut in the rear with 245 35 18s rims 18 8.5s with 47 offset 255 35s would have rubbed...
areg
Old 02-04-2004, 02:14 AM   #20
rex n effect
Member#: 15289
02 wrx pollen silv
areg
Good info. What tires do you have?
Old 02-04-2004, 02:20 AM   #21
Sev
Member#: 8364
4.5 STi
dirty
GRbs
Old 02-04-2004, 02:40 AM   #22
rex n effect
Member#: 15289
02 wrx pollen silv
not familiar with those
GS-D3?
Old 02-04-2004, 07:03 AM   #23
Sev
Member#: 8364
4.5 STi
dirty
Falkens
Old 02-04-2004, 01:19 PM   #24
STi-ll chillin'
Member#: 36124
2004 WRX STi
Silver/silver
Default need advice
areg
I've got 18 8.5's SSR type C's coming with a 48 offset, will I be able to run 245/35's?
What do you guys think/recommend for tire size?
STi-ll chillin' is offline   Reply With Quote
Old 02-04-2004, 08:35 PM   #25
STi-ll chillin'
Member#: 36124
2004 WRX STi
Silver/silver
Smile bump (sorry)
really would like some input here
18x8 size rims. What size tires fit on this? nos Tire & Wheel 13 05-05-2013 07:51 PM
what size tires for 18x8.5 manjambles Tire & Wheel 7 09-22-2009 03:34 PM
what size tire for 18x8.5 rims WRX_Karl Tire & Wheel 18 10-23-2008 12:39 PM
Is there a sticky? What size tires can I run on Stock 16" rims? reddevil Tire & Wheel 5 03-09-2008 10:03 PM
Volk CE28N 18X8.5 44ET 5X100 W/BFG KDW's suby44 RMIC Private Classifieds 3 02-19-2007 09:10 AM
