Old 01-26-2004, 08:35 PM   #1
Rocketcar
Member#: 12294
06 WRX Sea dan
Default Mod's caused premature gasket failure?
I was wondering if my mods could have contributed to the failure of my up-pipe gaskets. My car was/is at the dealer for brakes and they called me and told me my uppipe gaskets were toast. I have had less than expected boost for a while but hardly noticable. I maxed out at .10-.11 when I should be getting .12 on the stock gauge.
I am what I considered slightly modded as follows:
MRT turbo back, Vishnu IC hoses and Reflash.
My car has 54,000 miles.
So could theses mods contributed to the failure of the gaskets?
just wondering if I should expect this every so often or perhaps should this have been expected?
thanks
Rocketcar is offline   Reply With Quote
Old 01-26-2004, 08:39 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Depending upon how the turboback was installed, the top uppipe gasket probably should have been replaced when you did your turboback install.
Brian
Old 01-26-2004, 10:33 PM   #3
vile
Member#: 32371
'02 t-rex wagon
platinum
the failure could be attributed to the install, that's for sure. how long has it been in there? did you reuse the stocker? if not, what did you go with? and how long has it been in there?
vile is offline   Reply With Quote
Old 01-26-2004, 11:07 PM   #4
Rocketcar
Member#: 12294
06 WRX Sea dan
Irvine Subaru did the install on the turbo back. The exhaust has been in place for over 2 years. BTW it's a MRT. I don't know if they replaced gaskets, my guess is no because the car was less than 6 mos. old at the time.
Old 01-27-2004, 09:06 AM   #5
BlackEye
Member#: 36203
2003 WRX
Platinum Silver Met.
Default Wait a minute...
I could see replacing the turbo - downpipe gasket but why would you replace the top UpPipe gasket on a TBE install? You don't need to touch it. You all must be talking about some method for installation that I am unfamiliar.
IMHO it is theoretically possible that due to the wastegate being closed more (To build more boost) this forces more drag on the compressor wheel (to create the boost), would lend it self to making the impeller wheel harder to spin, hence more pre turbo pressure. However, I wonder though considering so much back pressure has been eliminated. The stock exhaust system would do the same type of things I just mentioned. To what degree I just don't know...
BlackEye is offline   Reply With Quote
Old 01-27-2004, 01:36 PM   #6
sonicblue
Member#: 25227
2012 Escape
I just did a TBE install and didn't replace the uppipe->turbo gasket (and some experienced scooby techs were helping). So, same question as above........
sonicblue is offline   Reply With Quote
Old 01-27-2004, 02:15 PM   #7
Wagon Joe
Member#: 34436
No reason to touch the uppipe during a TBE install, and I'm sure Irvine didn't as well.
I would tell them not to worry about it. Then, install a catless uppipe this weekend. (and change the gaskets while you're at it)
Wagon Joe is offline   Reply With Quote
Can BOV make premature turbo failure ? CosworthSTI77 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 11-30-2009 04:32 PM
could Hotchkis endlinks cause ball joint failure Ostrowrx Brakes, Steering & Suspension 14 07-22-2008 09:25 PM
lowering springs cause premature shock failure?? IllNastyImpreza Brakes, Steering & Suspension 3 02-21-2008 12:44 PM
Which of these caused my emissions failure? G.Subramaniam Normally Aspirated Powertrain 18 07-27-2006 11:43 AM
Premature synchro failure common? MachinesWRX Transmission (AT/MT) & Driveline 27 07-05-2005 11:58 PM
