Old 01-26-2004, 10:05 PM   #1
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Default Backlighting for Gauges and Climate Control
Hello, any help would be greatly appreciated. I recently purchased a 99 RS Turbo, and the lighting behind the gauge cluster and climate control doesn't work. I pulled both of these pieces out, the bulbs are fine and all the wire seems to be fine visually speaking. I also checked all the fuses and they are fine also. Everything else works perfect just the backlighting on these two pieces???????? Everthing on the cluster works also, even the backlighting for the clock, door ajar, brake light, and all of those warning lights????????? The car does have a Link Plus in it, but I don't think that this could affect it, and yes, I have checked the dimmer switch
HELP!!!!!!!!!!!!!!!!!!!!!
thanks in advance
99RSTurbo is offline   Reply With Quote
Old 01-27-2004, 10:45 PM   #2
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Any Ideas????
also the car does have an aftermarket alarm on it???
Old 01-28-2004, 04:11 PM   #3
qoncept
Member#: 44762
2013 BRZ
Check your fuses.
qoncept is offline   Reply With Quote
Old 01-29-2004, 01:46 PM   #4
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
You should use some sort of voltmeter. I don't think looking at bulbs and fuses and saying that they are ok is reliable.
Schlad is offline   Reply With Quote
Old 01-29-2004, 01:53 PM   #5
qoncept
Member#: 44762
2013 BRZ
..but looking at fuses and saying "They're blown" is a pretty reliable way to know that's youre problem. ::]
Old 01-29-2004, 04:05 PM   #6
Schlad
Member#: 25433
2003 WRX SW
all we'll drive
LOL You know what I mean... I've seen bulbs and fuses that look good even though they are not. But yeah, if you definitely see a gap in the fuse, I'd say that is pretty obvious.
Old 01-29-2004, 11:15 PM   #7
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
I have already done the obvious!!!
Just need to know if this has happened to anyone else and what a possible solution might be.
Old 01-30-2004, 12:55 PM   #8
Tobey
Member#: 21400
2015 WRX Limited
ISM
i blew the lights in my gauge cluster on my old car. i had shorted out on of the traces on the backside of the circuit board. my not relate to your situation but that shows you it could be anything in the car.
i would buy the subaru electrical manual and start there (since you have tried the obvious). if you bought it from a dealer i would bring it back (although i doubt you did buy it from a dealer).
Tobey is offline   Reply With Quote
Old 02-15-2004, 10:42 AM   #9
99RSTurbo
Member#: 53459
99 Impreza
Twin Turbo'd V8
Well guys, after weeks of pulling my hair out I finally fixed my illumination problem.
If this ever happens to someone else, there is a illumination control module, next to the glove box on the right side mounted to a piece of metal. It is a 6 wire box and was the culprit of my problems.
So there you have it
Old 01-10-2007, 11:18 PM   #10
XLR8_HFX
Member#: 137025
98 impreza
green
I know this is an old post but i was wondering where this module is located
XLR8_HFX is offline   Reply With Quote
Old 01-11-2007, 12:12 AM   #11
XLR8_HFX
Member#: 137025
98 impreza
green
any help???
Old 01-11-2007, 04:18 PM   #12
XLR8_HFX
Member#: 137025
98 impreza
green
i guess no one has any ideas?
hate your silver radio and climate controls? subeman90 Baja Forum 11 10-31-2015 09:42 PM
TX: 2005+ radio bezel and climate control unit ownnij Interior/Dressup/Audio & Security 1 11-14-2008 11:43 AM
NO dash lights and climate control lights blkbdrx Electrical & Lighting 4 10-24-2003 10:09 PM
