Old 01-26-2004, 11:09 PM   #1
subiebill
Member#: 24931
Default anyone know how to tune s-afc II
I went to have the car tested because the check engine light was on and the car keeps stalling. The outcome after being tested was that the car's air flow Need some expertise on the s-afc II and how to tune now that everything is installed. It started happening more often when I put the blitz sus air intake on and now even more after I put on the borla catback. Anybody have any thoughts about this.
subiebill is offline   Reply With Quote
Old 01-26-2004, 11:14 PM   #2
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
I'm curious, why did you go for the AFC rather than a proper tuning/reflash?
MB38 is offline   Reply With Quote
Old 01-26-2004, 11:21 PM   #3
subiebill
Member#: 24931
I have had the s-afc II since I had my 2001 RS so when I purchased the wrx I installed the afc before I started installing the intake and the exhaust and I am a noob with the wrx so I appreciate any help on this, thanks.
Old 01-26-2004, 11:45 PM   #4
wRx14pSi
Member#: 6203
perhaps a message forum isnt the best way to tune the safc 1 or 2. try to find someone local with knowledge. its really hard to say what your values should be set at. since maby thing like ambient temp, air, fuel, etc..
try resetting your ecu see if that helps a bit
wRx14pSi is offline   Reply With Quote
Old 01-26-2004, 11:48 PM   #5
MB38
Member#: 51588
2006 WRX TR
1997 Supra Turbo
subie, I didn't mean for the post to sound offensive, don't worry about it.
It would be best to take it somewhere and have it tuned (which will probably cost just as much as a reflash would). It's a difficult still to acquire.
Old 01-26-2004, 11:59 PM   #6
subiebill
Member#: 24931
I am not taking any offense to it I am just frustrated with the rough idle and the constant stalling. So hopefully someone would be able to help me out and figure out how to set this where i am lost with that and I appreciate your suggestion.
thanks
Old 01-27-2004, 11:20 AM   #7
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
are you sure all your settings are correct? double check those before anyhting. it should not be idling rough at all and definitly not stalling. also, what mods do you have?
angryfist is offline   Reply With Quote
Old 01-27-2004, 11:27 AM   #8
wRx14pSi
Member#: 6203
Settin 2 Hi low throttle shoudl be 10% and 70%
Setting 3 Hotwire ---> 1 to 1
car 4 cyclinder with arrow up
this should provide smooth idol
On the contrary in the northeast .. www.turbotrix.com will dyno tune your SAFC if you book 1 hour of dyno time.. well below the 200 dollar mark..
Old 01-27-2004, 11:42 AM   #9
subiebill
Member#: 24931
the mods would include blitz bov, blitz sus intake, and the borla exhaust. The rough idling kept getting worse when I started putting more mods on the car. Any ideas on that. I will call up turbotrix and see what they think and if it needs to be dynoed I will setup an appointment with them. Thanks guys.
Old 01-27-2004, 11:43 AM   #10
subiebill
Member#: 24931
forgot to mention s-afcII and rsm on the list of mods as far as electronics and engine parts go
Old 01-27-2004, 04:45 PM   #11
angryfist
Member#: 22760
#54 STR S2000
crazymonkeyracing
you should be at hotwire 20/20 not 1/1. with that few mods you should definitly not be idling bad. i would take out the safc and see if the idle smoothes out. or you can jsut unplug it and stick a wire from yellow to white to connect the maf wires and turn the car on. if this does not work then there is something else wrong with your car.
also make sure your a/f correction settings are all at zero.
Old 01-27-2004, 05:11 PM   #12
CatchME
Member#: 22732
You can't tune it untill you put it on a dyno with a wideband or get some kind of 0bd2 data logger (www.pocketlogger.com). Try putting your LO values a few into the positive - that should give you a bit higher idle or you can just take that intake off considering all it does is confuse you MAF - or you could check for vacum leaks in the intake area . Anyways, here are some very useful SAFC tuning guides:
http://home.comcast.net/~tarryo/kyle/tuning.html
http://www.roadraceengineering.com/newafc-print.htm
And incase you have access to a pocketlogger:
*keep in mind the guide is for a dsm but it will give you an idea of how use one*
http://www.vfaq.com/TMO/Tuning-Tips.htm
http://hywell.org/plhelp/data.html
Good luck, Zach
CatchME is offline   Reply With Quote
Old 01-28-2004, 08:52 AM   #13
subiebill
Member#: 24931
thanks, i am gonna try tuning the afc at work today and see how that goes and then if that doesn't work i will play around with the maf sensor and if that doesn't work i will take off the blitz intake and put the stock intake back on
Old 01-28-2004, 09:07 AM   #14
wRx14pSi
Member#: 6203
also take a voltage meter and see if the maf sensor is good or if the TPS sensor is good.
Anyone Know How To Tune A 05 Rs In The Hanover Pa Area????? smithrcing17 Open Source Reflashes 14 02-26-2009 06:53 AM
Anyone know how to tune a UTec? wRxbeater11 Tri-State Area Forum 1 04-13-2003 03:00 AM
Anyone know how to tune a link? pitbul09 Tri-State Area Forum 14 11-19-2002 06:05 PM
Which shop in the Bay Area knows how to tune an Apexi S-AFC ScrambleBoost Bay Area Impreza Club Forum -- BAIC 2 07-18-2002 01:16 PM
anyone know how to use S-AFC? sky Vancouver Impreza Club Forum -- VIC 2 12-15-2000 07:34 PM
Message Board Statistics All times are GMT -4. The time now is 04:04 AM.
