Old 01-26-2004, 11:26 PM   #1
cronic
Member#: 9749
Default Where is outside temp sensor mounted?
WHere is the sensor for outside temp on the JDM V7 sti's mounted? My friend has a V7 sti and i want to locate this sensor so i cant hook it up in my car and make my temp display on my V7 cluster..
Thanks
Dave
cronic is offline   Reply With Quote
Old 01-27-2004, 12:30 AM   #2
SlaminSuby25RS
Member#: 20425
99 2.5RS swapped
05 Legacy GT
it is the little black box in the center of the grill behind the badge next to your horn you will have to take the grill off to get to it.
SlaminSuby25RS is offline   Reply With Quote
Old 01-27-2004, 12:35 AM   #3
cronic
Member#: 9749
Is it visable in this pic?
I gotta look at the car.. So if i just trace the sensor to the CLuster and hook it up to the same pins in my cluster will it work? I have read the thread on this and it doesnt seem like too many are being succesful..
Old 01-27-2004, 04:00 PM   #4
brunetmj
Member#: 8023
2004 2.5 RS
Looking at the schematic the temperature sensor does not go to the gauge itself. It goes to the A/C Control module and then to the gauge..
brunetmj is offline   Reply With Quote
Old 01-28-2004, 12:06 AM   #5
SlaminSuby25RS
Member#: 20425
99 2.5RS swapped
05 Legacy GT
huh??? it should be mounted right there in the center i can't see it tho
where is the outside temp sensor topshotta10 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-13-2006 04:02 PM
where is air temp sensor in the STi? criz Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2004 09:30 AM
Outside Temp Sensor OneOBS Electrical & Lighting 4 07-22-2004 03:49 PM
where is the outside temp sensor? metoo STi Forum Archive 1 07-26-2003 09:49 PM
