Old 01-27-2004, 05:43 PM   #1
DreddRS25
Member#: 51642
2008 WRX
Default Nearly Dead Battery
Quick Q not trying to bump important questions.
If my battery won't turn over my motor after listening to the radio for 15-20mins and needs to be jumped, then does this sound like a nearly dead battery or maybe something else? I had my car off while cleaning my air filter while listening to music.
After I jump the car and let run for few minutes with both cars running, I am able to start up my Subie just fine. However, I have worked on my car twice in the past two weeks. Both times I have had to jump my car to get it started.
What do ya'll think, new battery or get a charger?
One other question. Would a failing battery allow the radio to distort at a lower volume. It seems like I can't turn up my radio too loud without getting distortion. I have a Alpine 9801 + Sony 6.5s XS1621 + stock rear speakers. Sometimes I can crank it up and other times seems like I can barely turn the dial up.
DreddRS25 is offline   Reply With Quote
Old 01-27-2004, 06:00 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
replace the stock battery there is a thread about this over in txic....STOCK SUBARU BATTERIES SUCK ASS!!!
ATX25RS is offline   Reply With Quote
Old 01-27-2004, 06:17 PM   #3
DreddRS25
Member#: 51642
2008 WRX
So, would a nearly dead battery cause an increase in radio distortion?
Old 01-27-2004, 06:43 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Lead acid batteries don't respond well to deep discharges - every time the battery is driven down to nothing, you significantly reduce it's capacity. (essentially forming a lead sulfate layer which effectively blocks the electrodes) - if the battery has died multiple times, it needs to be replaced.
If the battery is driven down, putting out a lower voltage than the radio wants, then yes, it will cause an increase in distortion.
DrD is offline   Reply With Quote
Old 01-27-2004, 07:37 PM   #5
DreddRS25
Member#: 51642
2008 WRX
Yeah I would drain the battery pretty quick without turning on the ignition. So I'll have to get a new battery. Off to Sears. Would get an Optima but here in Texas weather is always mild, so I'll stick to a Sears special.
So, if everytime I drain the battery, then I am essentially shortening its life?
Would an alternator drain the battery and still function without showing symptoms of failure? (Q on the side)
Old 01-27-2004, 08:29 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Yes.
The alternator won't drain your battery, but it could be undercharging it (you need to look at the voltage drop across the battery when the car is running - should be somewhere between 14 and 15V, give or take a little (not sure the spec on the Subie, but that's a pretty typical number))
Old 01-28-2004, 01:14 AM   #7
kenchan
Member#: 15106
dred- give it a good recharge with a battery charger. its possible
that your battery is not charged to the max enough.
as mentioned above, a regular acid battery will prematurely
wear if you drain it with your stereo running. if you want to do
that, you need to get some Optima Yellow tops (deep cycle)
battery. It will still drain, but it will be more constant power
and can be charged over and over many many times without
damaging it.
kenchan is offline   Reply With Quote
My battery...it is nearly dead. ScubaruImpreza05 Car Audio, Video & Security 17 02-03-2009 07:37 PM
Dead battery or bad battery Texas25RS Texas Impreza Club Forum -- TXIC 1 01-26-2004 10:24 AM
is my battery nearly dead? dorifto88 Car Audio, Video & Security 2 01-05-2003 11:24 PM
('93-'01) Week old 2002 2.5 with a dead battery deke Impreza Forum 5 08-30-2001 05:00 AM
Dead Battery = Dead Alarm? 2yLiTe Car Audio, Video & Security 3 01-16-2001 01:33 PM
