Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-27-2004, 12:35 AM   #1
taino211
Member#: 39347
2004 WRX
Question Spare Tire
Well, I'm looking into getting some new wheels for the WRX and was thinking of putting some 17" wheels to replace the 16".
My question is, if I'm riding on 17" wheels and I happen to get a flat tire, would/should I replace it temporarily with the 16" spare tire? Or should I buy a 17" spare tire (which then I would ask if a 17" wheel/tire will fit in the spare tire compartment... I'm assuming it doesn't)? Its common sense that you shouldn't put on one 16" wheel with three 17" wheels but would this be OK until I get to a service station or my house? Or would this damage the Subie's AWD system?
Any advice is appreciated.
taino211 is offline   Reply With Quote
Old 01-27-2004, 02:29 AM   #2
WRX 2002
Member#: 11211
2004 STi
Rally Blue
The existing spare wheel will work, as the diameter of the the 17in wheel / tire combination (should be) the same as the stock diameter wheel / tire conbination.
205/55/16 is the same (or very close in diameter) as the 225/45/17 in combination. The only area where you might run into problem is you installed a BBK on the front that requires 17 rims.
Nigel.
WRX 2002 is offline   Reply With Quote
Old 01-27-2004, 03:10 AM   #3
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
So unless my spare is nearly exactly the same diameter as my other 3 wheels/tires, I can't use it? How much does the difference have to be to be unacceptable?
whtlegacy is offline   Reply With Quote
Old 01-27-2004, 10:05 AM   #4
ten80
Member#: 53625
00 16' FXT
1/4" is the maximum recommended diameter difference, and you may not be able to fit a 17" spare in the spare tire bay because the tire is fatter (just a thought... I am not certain)
ten80 is offline   Reply With Quote
Old 01-27-2004, 11:27 AM   #5
taino211
Member#: 39347
2004 WRX
Has anyone been able to do this? Fit a 17" x 7.5" tire/wheel in the spare tire bay?
Thanks in advance.
-Ryan
P.S. Just to make everyone jealous, its about 73 degrees here...
2004 WRX STI Spare Tire and 2006 WRX TR Spare Tire! 06TRDude Wheels/Tires 5 05-09-2016 12:04 AM
FS:(PA) Subaru 17' spare oem tire & classic VW oem spare tire yo14jman Wheels/Tires 1 06-26-2008 07:17 PM
fs delaware pick up spare tire spare tire blueghost Wheels/Tires 4 06-13-2007 09:58 PM
WTB: wrx/sti floor matts, spare tire, spare tire cover Lach Vancouver Impreza Club Forum -- VIC 3 03-31-2005 09:03 PM
Will the spare tire cargo area hold a full-size 16 inch spare? Big_Hitter Texas Impreza Club Forum -- TXIC 21 08-21-2002 03:43 AM
