Old 01-27-2004, 02:37 AM   #1
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
Default EJ25 dohc heads+ phase 2 block = what compresson ratio?
hey, pondering a cheap way to gain compression to bump some more NA power,
add my DOHC EJ25 heads to the 10:1 phase 2 block and use the thin head gaset from the phase 2. anyone have any ideas of waht the compression ratio would be?
there are numbers here, but i cant do the math (hate math)
link:
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
h
supermoose is offline   Reply With Quote
Old 01-28-2004, 04:58 PM   #2
supermoose
Member#: 9093
swap starr
bmp!
Old 01-29-2004, 11:59 AM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default talked to wac
I have this setup unfortunately. And using the DOHC gasket wac guestimated my compression ratio to be 10.3-10.5 with out being there and doing his own messurements.
Joshua
yebokmj is offline   Reply With Quote
Old 01-29-2004, 03:07 PM   #4
supermoose
Member#: 9093
swap starr
hmm. do you like it or not? any idea what compression ratio with DOHC gasket / SOHC gasket?
h
Old 01-29-2004, 03:20 PM   #5
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
EJ20 info for myself
http://www.offroadvw.net/bajawes/V6_baja/compare.html
And for Comp. Calc:
http://www.race-cars.net/calculators...alculator.html
Just some dumb links, you need to know dome/dish etc. and that requires searching and <I'm lazy.
I think by changing by only a +10mm in gasket wouldn't increase it that significantly. (maybe + .1-.2 tops) But I'm trying to find out about swaping heads for most EJ's and trying to find a nice NA or nice turbo compression that would work "in theory" in my 1.8 > 2.0 thread. Maybe do some nice Eagle rods or similar and change ur piston to domed +10-15 if u wanna build it up that much. I'm not sure how much the block can hold tho.
EDIT: Just looked at that link up top...AWESOME info.
Thanks for posting that!
WRX34
WRX34 is offline   Reply With Quote
Old 01-29-2004, 05:24 PM   #6
yebokmj
Member#: 2213
Brilliant Red
Default Valve clearance?
I wonder if there would be valve clearance issues with the SOHC gasket? Anyways as to the compression with a SOHC all I can guess is hight than with the DOHC maybe as much as 10.7?
Joshua
Old 01-30-2004, 11:31 AM   #7
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
todnar is offline   Reply With Quote
Old 01-31-2004, 03:52 AM   #8
supermoose
Member#: 9093
swap starr
12:1 is kinda crazy, not completely understanding how the differance between 2 phase 2 ej25 sohc bottom ends would be so differnt
could you explain? (i dont know much engine math)
h
Old 02-02-2004, 01:10 PM   #9
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
You really have to cc everything out and know how much the piston is above, below or flush with the deck at TDC to get exact static CR. The numbers I got are calculated from the charts on Wayne's site.
This is for 98 DOHC heads with SOHC gasket on the 1999 and 2000 block.
To get CR you add the swept volume (616) to the combustion chamber volume (1999 = 65.5, 2000 = 56.5 ) and divide that by the combustion chamber volume.
To get combustion chamber volume you add the quench, head and piston volumes together.
1999 would be 616+65.5 =681.5/65.5=10.40:1 CR.
2000 " " 616+56.5 =672.5/56.5= 11.9:1 CR.
The differance between the two years is 99 has a piston volume of 15cc's and 2000's is 6cc's. Thats 9cc's less in the 2000's combustion chamber volume and that's why the 2000's CR would be higher.
I added the piston volume to the swept volume in my earlier post and thats why the CR was even higher.
Hope that helps.
Cheers,Tod
Old 02-02-2004, 01:14 PM   #10
yebokmj
Member#: 2213
Brilliant Red
Default 2000 and DOHC gasket?
What do you get for the 2000 block with DOHC heads Phase 1 and a DOHC gasket? Just would like another person's math on this one to confirm what I was told.
Joshua
Old 02-02-2004, 04:00 PM   #11
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Default Joshua
From his charts I get
616+63.8=679.8/63.8 = 10.65:1 CR.
Thats if your pistons were flush with the deck at TDC and thats not adding piston volume to the swept volume. Then it would be
10.75:1 CR.
-Tod
Edit for spelling
Old 02-02-2004, 11:18 PM   #12
supermoose
Member#: 9093
swap starr
thanks man. ir hate maff.
anyone know if the valves will clear if i run the SOHC gasket??
h
Old 02-02-2004, 11:33 PM   #13
yebokmj
Member#: 2213
Brilliant Red
Default BAD
Thanks Tod, I wonder how long this engine is going to last under boost? It's been fine for awhile but I am curious if the warm weather will be the end of it.
Joshua
Old 02-03-2004, 02:12 PM   #14
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Your guys are welcome.
Can't help you on the longevity on your motor question.You've heard it all before I'm sure.
-Tod
Old 03-31-2005, 02:25 PM   #15
paulpas
Member#: 83650
I'm getting an engine rebuilt in my 97 Outback with a new short block. Subaru wont sell anyone a refurbished phase I block so I got a brand new phase II block. My heads are being milles but I do not know how much. They did mention that they had to shave the valve stems a bit so they'll clear. They're using factory recommended head gaskets. I'm trying to find out what the compression would be if the milling is not accounted for. From your calculations it seems that it would be 11.9:1 (*joy*). Did I misread your calculations?
paulpas is offline   Reply With Quote
Old 03-31-2005, 03:18 PM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
You didn't misread the calcs. It really will be that high......higher with the milled heads. The tipping of the valvestems is to preserve the height in the head for the shims. Unless the person doing it is very-very meticulous....you'll still be searching around for shims to get the clearances right. Ask me how I know.......
Jay Storm
Old 01-09-2016, 02:51 PM   #17
scar13
Member#: 425679
Hi, I know this is an old thread but it is exactly what I need info on. (rather than start a new thread). I have a 98 Leg Outback with an EJ25D Auto. I'm pulling the rod knock boat anchor and have a 251 (2000 MY) short block. I just want a daily driver. Question 1: How high a compression ratio can I have and still run 89 octane ? Question 2 : Using a Cometic MLS H. G. Using the above formula, how thick of a gasket will I need? I'm not great at math and these links are old and don't work; can an experienced guru help a newb out please? Thanks in advance for any help!
scar13 is offline   Reply With Quote
Old 01-10-2016, 01:34 PM   #18
Storm
Member#: 5218
96L Most Over-
Developed Beater
You can use the stock phase 2 shortblock with EJ251 headgaskets (.040") or EJ25D gaskets (.065"). The compression ratio will be slightly higher with EJ251 gaskets but will run completely normal on regular pump gas.
FWIW, every time I saw a warranty replacement shortblock for the famous EJ25 piston slap.....it was an EJ251 shortblock.
Use the '00 EJ251 shortblock and .040" headgasket. There will not be any problems.
Jay
Old 01-11-2016, 02:21 AM   #19
scar13
Member#: 425679
Great! Thank you very much for easing my worries, sir.
ej25 DOHC to Phase 2 SOHC JDM Importers Subaru Conversions 4 04-11-2014 06:44 PM
Headgasket advice for phase 2 block with DOHC heads ciper Subaru Conversions 1 11-07-2008 04:53 PM
WTB: Phase I Ej25 DOHC Heads and Intake BhamRoadrunner Private 'Wanted' Classifieds 1 10-10-2006 09:56 AM
EJ25 dohc heads+ phase 2 block = what compresson ratio? supermoose Normally Aspirated Powertrain 2 01-29-2004 02:58 PM
