Old 01-27-2004, 07:42 PM   #1
spaz_666
Member#: 37381
'12 JSW TDi
Reflex Silver
Default new age impreza: REAR fog-light?
i've seen European & UK GC8s with them.
Anyone have any info on parts & installation or pics of the rear light cluster on a new age impreza with a rear fog-light?
i already searched NASIOC & checked ScoobyMods.
Thanks.
spaz_666 is offline   Reply With Quote
Old 01-29-2004, 12:18 AM   #2
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
Couldn't you base off some info from this ScoobyMod thread?
http://www.scoobymods.com/forums/sho...light=rear+fog
I know some wiring differences with the new MY04, but it should give you an idea.
-paK +1
Pakin is offline   Reply With Quote
Old 01-29-2004, 06:29 PM   #3
spaz_666
Member#: 37381
'12 JSW TDi
Reflex Silver
-paK +1
Yeah, i saw that thread at Scoobymods...
Before i start a rear fog-light project, though, i'd at least like to know which lamp position in the rear light cluster should be the fog-light.... thus my request for pictures.
Old 01-29-2004, 06:51 PM   #4
jac04
Member#: 49895
09 Forester
06 Legacy 2.5i Wagon
I looked into this for my 04 WRX wagon after seeing the rear fog light on a few cars in the Subaru of Australia accessories booklet. The photos show that one of the reverse lights is red instead of clear, and I confirmed that this is indeed the rear fog light. I was quoted $327 plus shipping, but this was for a RH light assembly with fog light. For the US, the rear fog would need to be on the left. Anyhow, you could simply get a red 7440 bulb, install it in place of the LH reverse bulb, and then wire it to come on only with the front fogs on and an 'arming' switch on.
-Jeff
jac04 is offline   Reply With Quote
Old 01-29-2004, 07:08 PM   #5
jac04
Member#: 49895
09 Forester
I just remembered that the sedan rear lights are different from the wagon. Sorry. It still looks like you might be able to wire one of the rear lights to come on as a fog. According to the manual, the bottom center bulb is for a tail light only, but it uses a 7443 dual filament 21W/5W bulb. Maybe you could wire the 21W side of the bulb as a fog.
Old 01-31-2004, 03:34 AM   #6
it8ezbngrn
Member#: 35590
A 21 watt light bulb is bright. Brighter thna you would think. I had a Del Sol that had the Honda EDM fog light that I had installed. It was too bright and I eventually dropped it to an 8 watt. I was afraid I was gonna get pulled over.
Also the center bulb in the taillights is a dual filament bulb. The high wttage side is not wired at all. the wire is under the blue tape. You can use that. I connected mine to the brake circuit. Giving me 3 bulbs per tailight that light up as brake lights.
it8ezbngrn is offline   Reply With Quote
Old 05-03-2004, 12:45 PM   #7
DomozitoLK
Member#: 58668
2015 WRX Limited
Lightning Red
I re-wired my 1997 VW Golf Cabrio to european style lighting with integrated rear fog on the drivers side using a wiring diagram from an Italian-spec car found on the web and from other VW'ers who did similar conversions.
My 2004 WRX tail lamp setup look exactly like the US-spec VW Golf tail lamp setup. I bet the rewiring would be very similar. I think all you'd have to do is source the rear fog switch and do the re-wiring.
On the sedan, it basicall makes the outer most lights brake lights, the center light a parking light and the inner most lights the fog light. Some have opted for just the driver's side and others wired both as rear fogs. I had only the drivers side wired.
DomozitoLK is offline   Reply With Quote
Old 06-05-2005, 04:46 PM   #8
flippy
Member#: 68887
2004 WRX
Yeah, you are right. The outer most rear light is for brake light only, it only comes on when brake is applied. However, in NAmerica, this light is on for driving and brake light. The inner rear light is used for rear fog light in countries outside fo NAmerica. This light however comes on as another brake light in NAmerica.
I would like to know where you got the wiring diagram to convert the NAmerican wiring to the European wiring?
flippy is offline   Reply With Quote
Old 06-05-2005, 08:54 PM   #9
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
if you do a search there was a thread a couple of weeks ago about the rear fog in an 04. the middle bulb on the cluster is a dual filament bulbt that is not wired in. some one wired that into a fog switch . i will find the thred
ATX25RS is offline   Reply With Quote
Old 06-05-2005, 08:57 PM   #10
ATX25RS
Member#: 4597
and here you go.
Rear fog how to
B9 Tribeca amber rear signals and rear fog light DomozitoLK Tribeca Forum 4 02-01-2007 12:42 AM
Rear Fog Light Mod, Anyone done it? wrxEMT Interior & Exterior Modification 4 11-23-2001 12:21 PM
('93-'01) Rear fog lights on 2002 WRX US models ?? ginowrx Impreza Forum 15 06-15-2001 06:34 AM
Rear Fog Light Kit HRE | giulio Interior & Exterior Modification 19 05-12-2001 06:48 PM
