Old 01-27-2004, 09:17 PM   #1
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
Default UTEC w/ reflash tuning
This is an open ended question, but....
I have an ECUtek tuned for 550s w/ stock afrs I am using a UTEC for all fuel/timing tuning. I now have 740cc inj. If my 0% fuel column was 0's "about" what would it be with 740cc? I just want to start in the ball park to make things easier. I remember Riftswrx took out 7 across the board w/ 785cc's and got close. Does that sound right?
Thanks
Jim
mr2guru is offline   Reply With Quote
Old 01-28-2004, 02:47 PM   #2
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
I've never done exactly that, but it sounds relatively close. I'd use a copy of DD to center your fuel learning in CL, but I would think that you would get at least within the learn range with those settings. I don't know the equation off hand for MAF volts vs. real air (and thus real fuel), but if you're within the learn range, it will run OK in CL fueling. Hook up DD, check the fuel learning, and try to get it close to centered by changing the UTEC 0% col when the car is warm. Then the 0% col should work - you just have to test out actually driving it at less than your TPS OL fueling crossover to see if it can hold the right AFR and learning stays moderate.
Have fun...
-Sean
big_adventure is offline   Reply With Quote
Old 01-28-2004, 05:46 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
I read that at projectWRX also. I have the 785cc's and taking seven out across board seems to be a good starting place, based on the stg4 map. My EGTs were fine. It will at least get you in the right direction.
TyranosaurusWRX is offline   Reply With Quote
utec vs reflash subbydo UTEC 6 07-16-2010 12:38 PM
Utec or reflash??? johnwrx Open Source Reflashes 4 10-01-2008 10:57 AM
Meet Reflash Tune In Las Vegas Delicious Tuning South West Impreza Club Forum -- SWIC 0 01-24-2004 02:42 AM
EcuTek reflashing / tuning in Phila - Easter? Ken C Engine Management & Tuning 0 03-25-2003 01:13 AM
