Old 01-27-2004, 10:51 PM   #1
1stgearsyncro
Member#: 34886
Default Passanger Window Switch problem
So I just bought my replacement WRX (2nd one, just sold first one, too many problems) and I just ran into a small... and weird problem with my new car....
The passanger side window switch doesnt allow the window to go up or down (doesnt work)
yet when you use the drivers side 4 way switch to control the passanger window it works.....
and yet also on the passanger side door panel the door lock control on that side functions properly....
Any ideas?
-Zac
1stgearsyncro is offline   Reply With Quote
Old 01-28-2004, 04:22 AM   #2
DrewXT
Member#: 53521
2004 Forester XT
It will be a dead switch, that has most likely been disconnected, as the switches are in a return loop...
I had the rear switch on my Forester die, and I could wind down, but not up... the switch could be disconnected, and would work, but with it connected, wouldn't...
If you bought from a dealer, take it back... Should still be under a secondhand warranty...
DrewXT is offline   Reply With Quote
Old 02-15-2004, 12:10 PM   #3
1stgearsyncro
Member#: 34886
bump, took off the unit everythings connected etc.... anyone know if the window switch (like the unit with the port for the wiring plug is seperate from the whole unit including teh door lock switch and the door handle (the cup handle) or so i need a whole long piece?
-Zac
Old 02-16-2004, 09:05 PM   #4
1stgearsyncro
Member#: 34886
bump
Old 02-17-2004, 02:00 PM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
19 bucks for a new switch, it can be purchased separately.
cdvma is offline   Reply With Quote
Old 02-18-2004, 06:33 PM   #6
Brento
Member#: 24485
02 RS
make sure the driver lock out switch isn't engaged (small square button front of the other buttons). that sounds like that might be your problem vice bad switch.
Brento is offline   Reply With Quote
Old 03-13-2008, 02:16 PM   #7
northernwrx
Member#: 165099
2006 wrx
where can i get jus the switch part???
northernwrx is offline   Reply With Quote
Old 03-13-2008, 04:10 PM   #8
ioeth
Member#: 173554
2004 Impreza WRX STi
World Rally Blue
Before I went and bought a new switch I'd go get a can of contact/control cleaner & lubricant from my local home improvement store. I've had a can of the stuff that I've used for years and it's restored many "broken" window and lock switches on a variety of cars to perfect working condition. Just hose the inside of the switch down with the stuff, move it around a bit to work the cleaner in, and let it dry for a short while before turning the ignition on and testing it. At the worst, you'll be out $5 for the can of cleaner which you will most likely use successfully in the future anyway, and you might wind up saving the extra money from a new switch.
ioeth is offline   Reply With Quote
Old 03-13-2008, 04:14 PM   #9
northernwrx
Member#: 165099
2006 wrx
yeah i should give that a try for sure. what is the best way to get at the window controls. i am new to subarus so i dont know if i have to haul the whole door panel off or not.
Old 03-18-2008, 08:57 PM   #10
impreza_GC8
Member#: 123295
2000 2.5RS moneypit
2012 Ford Fusion 6MT (DD)
I have this same problem in my '00 RS. Haven't figured out a way to fix it yet, I suppose I will just end up buying a new switch altogether.
impreza_GC8 is offline   Reply With Quote
Old 03-20-2008, 11:30 PM   #11
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
I love how people go for the most technical answer when sometimes it is the simplest one that fixes the problem
Check all the other windows from their switches. If they do not work, then the window lock is on.
If that was it, you might also want to check the child safety locks. Someone might have had a child(ren) and put all the locks on.
RexyGirl is offline   Reply With Quote
Master window switch problem Lee MD Legacy Forum 9 03-21-2009 12:59 PM
Power Window Switch Problem! cbr_boi Electrical & Lighting 2 08-14-2008 09:05 PM
Passanger Window Replacement Lucky Loser Texas Impreza Club Forum -- TXIC 0 05-13-2007 09:45 PM
Window switch problem digitalboy40 Electrical & Lighting 0 03-20-2007 11:56 AM
Auto Passanger window Deznuts05 Technical Forum Archive 1 08-18-2000 06:26 PM
