Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 01-27-2004, 11:08 PM   #1
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
Default power steering problem
Ok.... I was running hard down a canyon and about half way down I hear a weird noise (like the noise the power steering makes when you turn the wheels all the way to the left or right) but MUCH louder.
So i pull over and let the fluid cool and i didnt make the sound again
Im thinking I over heated the power steering fluid. Does that sound like what i did?
if so how do i change it out and what fluid should i buy?
~Leor
WRC1 is offline   Reply With Quote
Old 01-27-2004, 11:12 PM   #2
QfactorRS
Member#: 30495
i change mine every other oil change
i use valvoline power steering fluid.
Q
QfactorRS is offline   Reply With Quote
Old 01-28-2004, 01:18 AM   #3
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
do you do it yourself? If so how?
Old 01-29-2004, 12:33 PM   #4
QfactorRS
Member#: 30495
disconnect one line
empty content, then hook up a small pump to the line, suck all liquid out, then refill slowly, making sure to not make any air bubles.
reconnect everything.
as easy as an oil change.
Q
Old 01-29-2004, 07:16 PM   #5
WRC1
Member#: 47803
2000 Impreza 2.5 RS
Blue Ridge Pearl
which line where is it? and is there anyway to do it without a pump
Old 03-23-2004, 10:43 PM   #6
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
Would like to know also
edit: Search for power steering fluid turkey baster
mtb_dude is offline   Reply With Quote
Power steering problem Br0kWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-17-2002 01:13 PM
Power steering problem subix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-01-2002 01:28 AM
Different Power Steering Problem? Mister Toro Warranty Issues & SOA Problems 4 11-08-2001 10:06 PM
Power steering problem ZMANNH25rs Warranty Issues & SOA Problems 4 10-17-2001 11:39 AM
Power steering problem? psoper Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-08-2001 08:07 PM
