Old 01-27-2004, 11:19 PM   #1
shadymilkman129
Member#: 53651
Cert Suby tech
specialist for hire!
Default utec help
Im having a problem with my utec. I dont have a laptop so im using the 9v adapter to use it on my pc. When i establish a connection with my pc on hyperterminal nothing comes up. I tried it on another computer also. I pressed control x and every other button and nothing...
shadymilkman129 is offline   Reply With Quote
Old 01-28-2004, 04:06 PM   #2
wrx plus
Member#: 42253
2003 RWD WRX
Alcohol injected, WRB
Push enter.
wrx plus is offline   Reply With Quote
Old 01-28-2004, 05:35 PM   #3
shadymilkman129
Member#: 53651
Cert Suby tech
like i said i have tressed pressing every possible button and nothing comes up.
Old 01-30-2004, 07:18 PM   #4
shadymilkman129
Member#: 53651
Cert Suby tech
Do i need to have the stoc ecu attached to the utec when working on it outside of the car? And if so wont it reset when I unplug it? thanks
Old 01-30-2004, 08:05 PM   #5
TurboXS (Pete)
Member#: 16704
The UTEC does need the factory ECU to connect to Hyperterminal.
A few things to check;
1. Make sure that the 9V battery is fresh or the adapter provides at least 9V.
2. Check that there are no other programs, such as Hotsync, "hogging" the serial port.
3. Check which comms port (e.g. coms 1) you are using and make sure that Hyperterminal has selected that port. Make sure that the baud rate, stop bits and parity are set correctly. Hyperterminal will show that it is "connected" regardless of whether any of these are incorrect. When Hyperterminal reports "connected" it only indicates it is listening and transmitting to the assigned comms port. It does not indicate that it has a connection with the UTEC.
4. Start Hyperterminal first then power up the UTEC, or hit a key such as escape.
regards
Pete
(TurboXS)
TurboXS (Pete) is offline   Reply With Quote
Old 01-31-2004, 03:52 PM   #6
shadymilkman129
Member#: 53651
Cert Suby tech
Thanks pete!
Utec check sum error map corrupt!! UTEC help bluesube2000 Engine Management & Tuning 18 07-28-2005 04:45 PM
utec help? wont switch over into utec drifterx Engine Management & Tuning 3 11-27-2003 01:28 AM
Quick UTEC help needed 1quikrex Engine Management & Tuning 7 01-23-2003 07:47 PM
Anyone running a UTEC!!!!Help buchananracing Southern California Impreza Club Forum -- SCIC 2 01-05-2003 08:20 AM
UTEC help silver 02rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-15-2002 10:17 PM
