Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 01-27-2004, 11:26 PM   #1
balajc
Member#: 15393
MY00 2.5RS Coupe 5MT
Silverthorn Metallic
Have a Nice Day? what if I got a flat while on 215/45/17?
I recently put snow tire (stock size) on the OEM wheels on the RS...so when summer comes, I will be buying Rota with 215/45/17 ES100...
since 215/45/17 is roughly 1.5% smaller (in the case of ES100), what if I get a flat? I am not stupid enough to put the spare on the rears but would there be any bad effect if I put it on the front?
car is 2000 RS
what do people who run 215/45/17 in the summer usually do???
balajc is offline   Reply With Quote
Old 01-28-2004, 12:07 AM   #2
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
Hope I don't get a flat!
1.5% won't be that bad of a difference for a short period of time. it's not like you're going to be driving like that for the rest of the year or anything. Think of it as incentive to get your tire replaced.
I'm in a sticker spot. I have Subaru 4-pots up front and I don't know if my spare doughnut fits over them! If I get a flat in the front, I may have to do 2 wheel changes - one to remove a good tire in the back and put the spare there, and then the 2nd change to put the "good one" back up front.
We'll see - I'll test my doughnut spare when I swap my winter wheels back to summers.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 01-28-2004, 12:48 AM   #3
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Actually, I think you would be in BETTER condition than most.
Spare tires are smaller than STOCK sized tires (yes...even in our cars, they are smaller, which is why they put a 50 mile limit on them)...so you should be pretty damn safe with a spare for a day or 2.
DDMan is offline   Reply With Quote
Old 01-28-2004, 01:41 AM   #4
kenchan
Member#: 15106
btw, for those with aftermarket wheels, make sure you
carry the factory lugs with you in your trunk. some of those
aftermarket lugs are too small to hold the donut.
kenchan is offline   Reply With Quote
Old 01-28-2004, 05:16 PM   #5
balajc
Member#: 15393
I know the spare is narrower (135/70/16) than the stock 205/55/16 but I dont know if the rolling circumference is close...I dont have the size calculator with me right now
So it seems like I would be fine putting the donut on the front then. And the suggestion of keeping facotry lugs in the car is a good idea
Old 01-28-2004, 10:43 PM   #6
DDMan
Member#: 11221
2002 2.5 RS
Alright, I just did that calculation....and its pretty amazing.
Between a stock tire and the spare donut that sized the differences are:
Height (diameter) is 1.44"
Rollout (circumfrence) is 4.5"
At 60MPH, the donut is only traveling at 57mph.
Personally, that is why they put a 50 mile limit on our cars.
Old 01-28-2004, 10:57 PM   #7
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
Thanx for those of you who mentioned the factory lugs. I just swapped out for aftermarket and did not even think about the spare. I think I'll go throw 5 of the stock lugs in the car right now before I forget. While I'm at it I also need to kick myself in the a$$ for driving around with dead weight I couldnt even use.
Someone tell me I'm not the only one who forgot about this.
eyeballs is offline   Reply With Quote
Old 01-28-2004, 11:08 PM   #8
Orson
Member#: 25254
2003 WRX wagon
I wouldn't worry about it too much. At the very worst, you can let a little air out of your spare and drive extra slow. Looking at the spare, I somewhat doubt that it has the exact same rolling radius as even the stock 205/55R16. Plus remember that in the end, it is the wheel speed that matters (with respect to the differential) and that is a function of a lot of things, not just static radius.
I carry a full size 205/55R16 as a spare and I run it with only 28psi to match my 215/45R17.
Orson is offline   Reply With Quote
Old 01-29-2004, 02:02 AM   #9
theviv
Member#: 22689
2002 WRX wagon
Doesn't tire pressure have nothing to do with circumference of the tire? Whether your tire is at 28psi or 32psi it shouldn't make a difference.
Unless the extra psi actually stretches the outside of the tire significantly, I'm at a loss as to why it should matter.
Right? Somebody back me up on this....
theviv is offline   Reply With Quote
Old 01-29-2004, 02:35 AM   #10
Penphoe
Member#: 269
No, I think the 50mi limit is because the tread is so thin on the spare doughnut, that any long-term driving will cord the tire and cause it to fall apart! I'm not kidding. It's meant just to get you to the nearest service station to get the tire replaced - in theory of course.
Which begs the question, how FAR have people actually driven on the doughnut? Wouldn't it be funny if you wanted to go super "light" and ran 4 doughnuts instead of regular tires and wheels?
LaterZ!
Darren!!
Old 01-29-2004, 09:37 AM   #11
balajc
Member#: 15393
the spare size 135/70/16 is 5.78% smaller than stock
man, you guys were right I would be better off with 215/45/17
Old 02-04-2004, 06:32 PM   #12
Brest Phan
Member#: 29052
08 Evo X
03 WRX sold not forgotten
I drove from tx to ca once on a doughnut spare in a toyota tercell....
Brest Phan is offline   Reply With Quote
Old 02-04-2004, 06:40 PM   #13
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
I wouldn't do that if I were you. An underinflated mini-spare is more likely to self-destruct while you're driving.
Back in one of the late 1980's-era One Laps, there was a car that did it on mini-spares all around. In answering concerns about the spares' safety, they mentioned that high pressures were what they were using to help them last.
Coati is offline   Reply With Quote
Old 02-04-2004, 09:56 PM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Exactly right. They have "INFLATE TO 60PSI" on the sidewall for a reason! That's an awful small tire trying to carry the weight of the car, so you need the higher pressure.
And Darren, there's no worry about the tread wearing out in only 50 miles. I've driven for days at a time on a spare before with no problems. I just installed mine today ( ) and yeah, it doesn't have the full tread depth of a "real" tire, but it's way more than enough to last 50 miles.
Pat Olsen
'97 Legacy 2.5GT sedan
Rota Attack 17x7.5 on 215-45-17 - your impressions? smackedownz Tire & Wheel 4 05-16-2005 07:34 PM
What tire pressure recommended for street with 712's 215/45/17 on a 7.5 vapore0n Brakes, Steering & Suspension 2 04-14-2003 06:10 PM
Tire circumference Q for math whizzes. 26.2 miles on 215/45/17 WRX is actually... gtguy Brakes, Steering & Suspension 9 09-27-2002 03:58 PM
17'' oz sl's on 215/45/17 boysetsfire Brakes, Steering & Suspension 4 09-22-2001 02:06 PM
reccommended tire pressure on 215/45/17 for WRX GDA Brakes, Steering & Suspension 1 06-08-2001 06:49 AM
