Old 01-28-2004, 01:36 AM   #1
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Default Will 235 or 245s fit on a WRX?
I have Rota SDR 17" which are 7.5" wide. Can I fit 235/45/17s or 245/40/17s on the car without rubbing? Thanks.
Jay
Diversion is offline   Reply With Quote
Old 01-28-2004, 06:56 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
You can get away with 235/40-17 on a 7.5" wide wheel, but 245's will be too wide. You'd need at least an 8" wide wheel.
235's should fit on a sedan without rubbing, while you may have to get the fenders rolled in the rear to fit 245's. Depends if the car is lowered at all.
Old 01-28-2004, 11:39 AM   #3
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
i have 235/40/17s as my race setup... its a little bit smaller diameter but it does not rub.
i'm assuming you have a sedan... because if you have a wagon you'll definately need to mod you wheel well.
good luck
SD
suby_dude is offline   Reply With Quote
Old 01-29-2004, 01:45 AM   #4
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Yeah I have a Sedan.. So do you think 235/45/17s would rub? 235/40/17 is a little too small diameter wise for me.. didn't want to change my final drive ratio that much.
Jay
Old 01-29-2004, 07:16 AM   #5
mav1c
Hoodbridge!
Member#: 560
But 235/45-17's will also change the final drive ratio.
Old 01-29-2004, 05:39 PM   #6
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
Yes, but not as aggressively as 235/40/17s.. I don't want to change it THAT much.
Jay
Old 01-29-2004, 05:59 PM   #7
mav1c
Hoodbridge!
Member#: 560
I'd rather go smaller than bigger.
Old 01-29-2004, 09:46 PM   #8
Templar
Member#: 483
2010 RSV4
Aprilia Racing Black
Although it is out of the recommended wheel width, you can fit a 245 40-17 on Rotas and do quite well. trhoppe places extremely highly at nationals in SoloII and Prosolo with this combo.
Remember, it will fit, but it is not the ideal.
Templar is offline   Reply With Quote
Old 01-29-2004, 09:55 PM   #9
Vortechcoupe
Member#: 33262
E36 M3
93 notch, X3
245/40/17 would be really close to stock size, but prob needs a 8" wheel.
Justin C
Vortechcoupe is offline   Reply With Quote
Old 01-29-2004, 11:26 PM   #10
wRx14pSi
Member#: 6203
bump i need to know also.. so 235/40/17 will fit with no rub??
wRx14pSi is offline   Reply With Quote
Old 02-02-2004, 12:49 AM   #11
Diversion
Member#: 18651
2013 Civic Si Sedan
PMM
I'm going to settle on 235/45/17s.. which are a tiny bit larger diameter over stock.. but I figure better gas mileage can't hurt =)
Jay
Old 02-02-2004, 09:54 AM   #12
JPIQ
Member#: 30277
2002 WRX Japan Specs
Platinum Silver Sedan
I currently have 245/45R17 tires on my stock WRX rims.
They fit perfectly, and they are WIDE...
JPIQ is offline   Reply With Quote
Old 02-02-2004, 10:53 AM   #13
Nick M
Member#: 41247
and you probably have no bigger contact patch than a 225
Nick M is offline   Reply With Quote
Old 02-02-2004, 10:54 AM   #14
Nick M
Member#: 41247
ill bump this again as well, id like to know
Old 02-02-2004, 12:01 PM   #15
JPIQ
Member#: 30277
Say What?
I am Wider and BIGER
than my friend who has 235/45-17
I wonder Why?
And it's noticible to the naked eye!
Old 02-02-2004, 12:46 PM   #16
Nick M
Member#: 41247
Say What?
I wonder Why?
you stuffed 245s onto the tiny oem wheels and just because they fit, does not mean the fit as well as they could or your contact patch is as big as it could be
Old 02-02-2004, 02:47 PM   #17
JPIQ
Member#: 30277
In theory I agree,
However, my 245's are WIDER than my friends 235's
on the SAME rim.
But like you said I could get more contact if I got wider rims,
but then again the 245's on wider rims would RUB.
Old 02-02-2004, 04:00 PM   #18
Nick M
Member#: 41247
In theory I agree,
on the SAME rim.
wider does not equal to more grip
Old 02-02-2004, 06:53 PM   #19
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
I'm waiting for my wheels to come in, but I have 255/40R17 Victoracers, which are 24.9" diameter (ala Kumho's website). They are gonna go on some 17x8.5" Advan RG's.
Although, I'm starting to feel back because I'll be using my more expensive wheels just for racing
ScreaminFast is offline   Reply With Quote
Old 02-02-2004, 10:17 PM   #20
Mond'z
Member#: 25364
maybe this is a noob question... can 215 fit 7.5"?
Mond'z is offline   Reply With Quote
Old 02-02-2004, 11:18 PM   #21
cronic
Member#: 9749
Yup ..
cronic is offline   Reply With Quote
Old 02-02-2004, 11:50 PM   #22
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
WOW 255! I assume you need the fenders rolled for that to fit? You gotta take some pictures when you have them on the car. That would look awesome.
Zuffy is offline   Reply With Quote
Old 02-03-2004, 12:46 AM   #23
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
yea i'm having my body kit put on and painted, and i'm going to ask the body shop if they can custom flare the fenders, or roll them or whatever....
Old 02-03-2004, 04:39 AM   #24
MBPEJ20
Member#: 24360
2002 WRX Sedan
Question
So what would give you a better contact patch? 225/45-17 or 235/40-17?
MBPEJ20 is offline   Reply With Quote
Old 02-03-2004, 09:07 AM   #25
Nick M
Member#: 41247
235, on a wheel that can fit them properly
Will 04 trunk lid fit on 02 WRX? WRXVII Interior & Exterior Modification 1 11-03-2004 11:59 PM
Will 16" OBS Alloys fit on a WRX? xtrred Tire & Wheel 3 05-06-2003 09:37 PM
Will a 17x9 wheels fit on the WRX? Patrick [Buffalo] Brakes, Steering & Suspension 5 10-29-2001 08:59 AM
will 235/45 17's fit on a 17x7.5 w/50mm offset? couldnthinkaone Brakes, Steering & Suspension 2 04-30-2001 04:20 PM
