Old 01-28-2004, 02:52 AM   #1
OutbackOutback
Member#: 53698
01 Outback H6
White/Grey
Subaru Stars How to disable VDC??
Hi There
I have also posted this in the Newbie section
I am a Newbie from Down Under, with an Outback H6 with VDC. It is an 04/2001 Build and is prior to the in dash VDC off switch.
After circumnavigating Australia (28,000kms / 17,500 miles) I have identified there are times when VDC is down right annoying, and potentially dangerous (and regularly embarrassing) , Like deep sand and mud. I have a suspension Kit with H/D Springs and Lifting Blocks so we have an extra 3" of clearance (excluding the Diffs)
I realise the VDC is primarily a safety feature and after driving this distance with 40% on sand and dirt, it is fantastic especially when towing a trailer.
BUT.. .. does anyone know of an aftermarket upgrade that can offer the disabling of the VDC.
I have resorted to lifting the Bonnet (Hood) and pulling the fuse, but this takes out everything VDC, ABS etc.
Thnaks
Terry
OutbackOutback is offline   Reply With Quote
Old 01-28-2004, 03:36 AM   #2
555bat
Member#: 53464
98 impreza
white
you can put a switch in the vdc
to stop it working
but that means abs doesnt work either
555bat is offline   Reply With Quote
('93-'01) How to Disable the Air Bags malaki Impreza Forum 17 05-24-2001 10:09 AM
how to disable daytime running lights in WRX? christurismohk WRX Forum Archive 21 01-26-2001 09:03 AM
Message Board Statistics All times are GMT -4. The time now is 07:00 AM.
