Old 01-28-2004, 04:48 AM   #1
JF1GD2
Member#: 51728
Default Removing tires from one set and re-installing onto another
My question is, if I take some low mileage tires off my stock wheels and put them onto my new SSR's of the same diameter.
Since the bead has been set when they were installed new on the stock wheels, will it be a safety issue to try to pry off the bead and install them onto another.
The installation will be done professionally at a tire shop of course, but will the fact that the beads been broken and reapplied be a safety concern?
JF1GD2 is offline   Reply With Quote
Old 01-28-2004, 06:57 AM   #2
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Shouldn't be. I've swapped tires many times and never had a problem. Now if this was the 10th time the tires have been swapped, I'd be concerned.
mav1c is online now   Reply With Quote
Old 01-28-2004, 07:19 AM   #3
ellisnc
Member#: 4229
2003 S2000
Did someone say track day
Yeah as long as you don't tear the bead when you're trying to take the tires off. It's fairly easy to do if you're not paying attention. (ask me how I know ) Even if the rubber gets a little chunck taken out of the bead area as long as the reinforcing isn't damaged at all and the tire holds air you should be fine.
ellisnc is offline   Reply With Quote
DFW: Cheapest place to have a set of tires switched from one set of rims to another? gaugeof12 Texas Impreza Club Forum -- TXIC 17 08-18-2009 10:09 PM
How can I remove tires from wheels? RootUsr Tire & Wheel 24 04-21-2009 06:28 PM
Removing Tire from Rim? bcristea Tire & Wheel 2 01-08-2009 12:58 PM
So I remove, inspect, and re-install my air filter and here is what I get... NavyBlueSubaru UTEC 31 07-21-2006 10:37 AM
Removing tires from wheels ? ZMANNH25rs Tire & Wheel 11 12-14-2005 04:36 PM
