Old 01-28-2004, 12:35 PM   #1
TexRex2002
Member#: 36303
06 Evo IX
Default Wire loose in UTEC?
I have a weird anomaly with my UTEC:
It doesn't want to communicate with my laptop at all. I can press escape all I want, turn the ignition off and on, nothing...
However, If I firmly bang on the kickplate with my fist a few times and then press escape, it connects just fine! I have pulled up the kickplate to see if the serial cable was loose, but no. it is firmly screwed in.
Anyone else ever have this problem?
TexRex2002 is offline   Reply With Quote
Old 01-29-2004, 11:10 PM   #2
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
Double check your ground wire??
mtb_dude is offline   Reply With Quote
Old 01-30-2004, 02:28 AM   #3
Aaron'sWRX
Member#: 34150
02 WRX
Post
The ground wire is not needed for functionality of the UTEC or connection to it.
First, I wouldnt be hitting it. Secondly, make sure there is not other software running on the laptop that would be using that serial port. (ie: hotsync for palm) I have to hit enter twice for mine to come up. Have you double checked your software settings and hard set VT100 emulation?
When the utec was out of the car, could you connect to it with a 9v battery without problems?
Aaron
Aaron'sWRX is offline   Reply With Quote
Old 02-03-2004, 02:59 PM   #4
TexRex2002
Member#: 36303
06 Evo IX
Yeah, I probable shouldn't we pounding on it, but it was my last ditch effort to get it to work, and suddenly it did! Everytime I can't connect, beating on the kickplate seems to fix it. Very odd.
I was unable to connect with the 9V battery, although I didn't try for too long.
All com settings are proper. It works great after pounding on the kickplate.
I'd send it in to TXS, but I have 565 injectors, and I can't drive w/o the UTEC.
Old 02-03-2004, 03:04 PM   #5
digitaltekniq
Member#: 18029
I had precisely the same issues with mine - I had to get a replacement in the end - which Aaron ^ there now has
digitaltekniq is offline   Reply With Quote
Old 02-04-2004, 02:21 PM   #6
TexRex2002
Member#: 36303
06 Evo IX
Wait, he has the original one, or did you sell him the replacement?
How did TXS handle it? We're they nice enough to send you a new one and allow you to return the defective one after install?
Old 02-04-2004, 03:21 PM   #7
Aaron'sWRX
Member#: 34150
02 WRX
Post
Rich (digitaltekniq) sold me the replacement... I believe Rich bought the UTEC from garret at worldone performance. I think after he spoke with TXS, he sent the old utec to garret and got a new one back.
I would give TXS a call, so its documented that you have problems with your unit and so you can see what your options are.
haha... And Aaron, still hasnt installed the one he has now.. sory rich.. haha
Old 02-04-2004, 04:36 PM   #8
pegdrgr
Member#: 25693
2008 18x9" goodness
E85-380ftlbs @ 3100
Technically you can, you just can't boost much, run past 5500 rpm, or floor it !
You want to race again after you pull it?
pegdrgr is offline   Reply With Quote
Old 02-04-2004, 09:34 PM   #9
TexRex2002
Member#: 36303
06 Evo IX
Originally posted by pegdrgr
you can't boost much, run past 5500 rpm, or floor it !
That's what I said! Impossible to drive!
Warning: Dangerous monkey on the loose in ATL Templar South East Region Forum 14 03-16-2005 09:04 AM
Lion on the loose in California...and not one of those pansy mountain lions either Kaiser Off-Topic 24 02-18-2005 11:35 PM
Alrighty! Escaped (alleged) Murderer On The Loose in SD! Coati Southern California Impreza Club Forum -- SCIC 29 02-03-2004 01:27 PM
One reason why the DNC will loose in 2004 Chewy-WRX Off-Topic 26 06-26-2003 12:12 PM
Where ca I cut loose in CT? Ripper New England Impreza Club Forum -- NESIC 13 07-11-2001 07:14 PM
