Old 01-29-2004, 04:54 PM   #26
1FastSTI
Member#: 53235
2004 STI
Hey guys it all has the do with the "drive by wire" and the emission contols on the cars. I think someone has mentioned it already.
1FastSTI is offline   Reply With Quote
Old 01-29-2004, 05:37 PM   #27
rexxer
Member#: 27624
2014 WRX
No drive by wire on the WRX.
rexxer is offline   Reply With Quote
Old 01-29-2004, 05:46 PM   #28
rexxer
Member#: 27624
2014 WRX
Originally posted by fliz
That logic is flawed. The mass you remove is still spinning. It's momentum is not magically transferred to the flywheel upon clutch engagement.
The rpms rise because power is being generated in the engine (fuel igniting) without any load.
The power either comes from the ECU dumping fuel for a split second until the intake pressure is relieved (maybe to prevent lean combustion that would increase the EGT's and output of nitrous oxides) or a slow reaction between the release of the gas pedal and the closure of the TB.
Yes, sorry, you are correct.
Old 01-29-2004, 05:48 PM   #29
Slowpoke
Member#: 19879
2004 WRX
Java Black
Wow, I'm surprised we are on the 2nd page already and there has not been a single "It happens because you do not know how to drive MT" post.
It's not due to poor driving technique - although altering your driving technique can prevent it.
It's not momentum - momentum will not cause the flywheel to accelerate, it will only slow the rate of deceleration.
Edit: Fixed typo in the 2nd paragraph - I mean to say, it's NOT due to poor driving technique.
Slowpoke is offline   Reply With Quote
Old 01-30-2004, 12:15 AM   #30
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Originally posted by Slowpoke
It's due to poor driving technique - although altering your driving technique can prevent it.
I agree altering your driving technique can prevent this from happening. But I disagree that it is from poor technique. It is a quirk to modern turbo charged vehicles to which one has to adapt. You could have perfect technique for a Porsche GT3, but it would have to modified for the quirks of a turbo Impreza...
Stanley is offline   Reply With Quote
Old 01-30-2004, 01:53 AM   #31
alster
Member#: 37480
And that's why I got a lighter pulley...
Here's the link to my review http://forums.nasioc.com/forums/show...hreadid=491523
alster is offline   Reply With Quote
Old 01-30-2004, 02:09 AM   #32
kdmd2b
Member#: 6670
2002 WRX Sedan
WR Blue
Yes it can be avoided if you wait longer enough between shifts but I know that I can take my foot all the way off the gas before engaging the clutch and it still has the small blip.
kdmd2b is offline   Reply With Quote
Old 01-30-2004, 10:05 AM   #33
DISCOPOPE
Member#: 43339
2oo4 STi
URgt35r w/t3hM3finj3cki0n
not poor driving... not poor timing, as stated above, you can have the car in neutral, build boost, blip the pedal, and hear the hang/surge.... i'm betting on emmisions.
DISCOPOPE is offline   Reply With Quote
Old 01-30-2004, 03:55 PM   #34
Slowpoke
Member#: 19879
2004 WRX
Java Black
Sorry that was a huge typo on my part, I meant to say, "It's not due to poor driving technique". In the context of my entire message, or even in the context of that sentence that you quoted, I'm sure that makes a whole lot more sense now
Old 01-31-2004, 01:01 PM   #35
Zuffy
Member#: 35268
2004 WRX Stg2 & with
added PDX goodness
Hummmmm, this querk has always frustrated me, when the engine has boost and I go to shift, there's a unwanted blip between shifts. I guess there has to me a longer delay between the point where, the right foot is out of the gas and the point where the clutch is disengaged. The combination of actions still needs to be performed quickly and smoothy or else jerky shifts result. I guess practice makes perfect.
I noticed that it doesn't seem to happen in the 1-2 shift, but more on the 2-3, and 3-4 shifts. I assume it's because it's because the WRX is boost limited in 1st gear, so this problem isn't as prevailent.
Zuffy is offline   Reply With Quote
Old 02-01-2004, 12:40 PM   #36
rodon
Member#: 36372
'03 WRX Sedan
This has just started happening with my car at around the 12,000 mile mark - and I haven't changed my driving technique. I'm concerned the the BOV is hanging up a bit.
rodon is offline   Reply With Quote
Old 02-01-2004, 12:45 PM   #37
SWRX
Member#: 52706
I just got my 2004 WRX about 3 weeks ago, i noticed that "rpm jump" almost every time when I'm accelerating (doesn't have to be hard accelerating) and upshifting between 3500 rpm to 4200 rpm. I have about 1300 miles on my car. I noticed this "jump" when I first got the car... ...what to do?? what to do??
SWRX is offline   Reply With Quote
Old 02-01-2004, 02:37 PM   #38
Thevaliantknite
Member#: 49272
02 WRX & STi>Past
i checked this out last night and it doesnt do it when you let all the way off the gas. the gas pedal is erally sensetive and even basically when your foot is touching it it will have a little play. beacuse i put it in neutral to make sure and the rpm's go up about as much as the "spike". so i say that is how you drive, not the car.
Thevaliantknite is offline   Reply With Quote
Old 02-02-2004, 10:26 AM   #39
Undepelo
Member#: 34960
What would baby
Jesus say of OT?
Could it be that leftover boost in the mainfold is just pushing the pistons on the intake cycle even though there is no fuel?
Undepelo is offline   Reply With Quote
noise when letting off the gas crxgator Transmission (AT/MT) & Driveline 2 06-28-2009 10:25 PM
rpm spike when coming to a stop fnlyfnd Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-04-2008 06:20 PM
RPM spikes when shifting apak123 Newbies & FAQs 9 08-24-2005 02:15 PM
grr. EGT's spike when letting of the gas (highway cruise) :( munkis Normally Aspirated with bolt-on Forced Induction Powertrain 20 06-14-2004 06:32 PM
RPMs spike when shifting? quynce Newbies & FAQs 15 06-21-2002 05:42 PM
