Old 01-28-2004, 04:57 PM   #1
BluRu02
Member#: 42412
05 waggin
bullet
Question What do we think about this set up...[email protected]
Luke et al
Please tell me what you think of this set up.
Tires on a 02 WRX no suspension done. All stock.
18" ICW rims aprox 19 lbs offset is +42.
225/40/18 zr Yokahama parada spec II
Is this too heavy? How is the offset? Is it going to cause any early damage on my suspension, etc?
Thanks.
Bluru02
BluRu02 is offline   Reply With Quote
Old 01-28-2004, 05:48 PM   #2
strider98
Member#: 34815
you can't take the
sky from me
wagen oder sedan?
strider98 is offline   Reply With Quote
Old 01-28-2004, 11:56 PM   #3
BluRu02
Member#: 42412
05 waggin
bullet
sedan. Also What pressure should I be running? I have heard different things. I think I am running high. Aprox 40-42 all around
Old 01-29-2004, 10:03 AM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
the 42mm offset will push the wheel out too far and you will experience rubbing when cornering hard or when you have alot of weight in the car ... and even on some large bumps
Old 01-29-2004, 12:03 PM   #5
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
Default Re: What do we think about this set up...[email protected]
The rubbing issue is mute if you wish to run a bit more camber, say -2 degrees all around. Acheve this with the adjustable camber bolts tire rack sells. I see no wear issues with the +42 offset. The 19 lb is a little on the heavy for my taste, but in general it's not bad. Also look at the Kumho MX tire, and compare weights - check websites and call the manufacturer if need be (kumho lists them, yoko does not).
Kevin
Red Rocket is offline   Reply With Quote
