Old 01-28-2004, 04:20 PM   #1
slvrwgn
Member#: 32604
2003 Impreza WRX Wgn
Question Topsider.... anyone heard of it???
Was just shown the Topsider by my uncle, it's used to change your oil. It's basically a tube that you put where your dipstick goes that allows you to pump all the oil out of the car without removing the drainplug in the oilpan.
He uses it on his BMW, but suggested I make sure there isn't a baffle inside the WRX's oilpan that would prevent the tube from reaching the bottom of the pan.
Has anyone heard of this product or used it? Or know if our oilpan has a baffle that would prevent a tube from reaching the bottom?
slvrwgn is offline   Reply With Quote
Old 01-28-2004, 04:33 PM   #2
SupaSizeFries
Member#: 10088
2002 Wrx Sti back
from the Dead
I'd say just use a Fumoto Valve instead.
SupaSizeFries is offline   Reply With Quote
Old 01-29-2004, 10:52 AM   #3
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
The one possible problem with the oil-suckers is that they may not clean out any crud in the bottom of your oil pan that would get flushed out by the oil running out the drain hole. They use very small diameter tubing to fit down the dipstick hole, so it's not like you can vacuum up solids.
Jon Bogert is offline   Reply With Quote
Old 01-29-2004, 01:06 PM   #4
Slimey
Member#: 42487
2008 STI
Dark Gray Metallic
It's amazing how these threads recycle themselves...
Here's a recent thread: http://forums.nasioc.com/forums/show...hreadid=466274
Short answer -- topsiders don't work in modern Subaru engines because of a baffle in the oil pan. This has been stated in FAQ on the manufacturer's websites, and I have personally verified this.
A topsider is a perfectly valid method of oil change. It's been shown to be more effective then a gravity drain method at removing oil. Those that think there's crud left by this method really are not thinking it through. If crud is stuck to the oil pan, it ain't coming out by gravity or suction. If it's in solution, both methods are fine, and in fact suction performs a more complete evacuation of the oil in the pan, so therefore removes more of this so-called crud.
I use a topsider (I have the Griot's model) in my non-Subaru vehicles. Used correctly, this is a very clean, tidy, and complete method for removing the oil from the crankcase.
Slimey is offline   Reply With Quote
Old 01-29-2004, 01:13 PM   #5
slvrwgn
Member#: 32604
Slimey,
Thanks for the response, that was exactly the info I was looking for.
Upscale/Oontz: Anyone heard of The Daily Candy? poison Off-Topic 10 03-06-2006 11:38 AM
boost questions and has anyone heard of the 3/16 mod jacket03WRX Newbies & FAQs 5 09-24-2004 10:05 AM
OT: Anyone Heard of the Band "Fancy Trash?" asquaredrex New England Impreza Club Forum -- NESIC 0 05-01-2004 08:45 PM
Anyone heard of the Flash Mob? thetasha Mid Atlantic Impreza Club -- MAIC 12 08-27-2003 09:32 PM
NYC Guys: Anyone heard of the Q-Lounge? WRXURV8 Tri-State Area Forum 2 02-12-2003 09:17 AM
