Old 01-28-2004, 05:48 PM   #1
alacrity024
Review Crew
Member#: 49476
Default ABS on/off switch?
is it possible to wire an on/off switch up to the ABS so that it can be de-activated at will?
is it possible to do this without voiding the warranty?
..didn't think so
is it possible to do this and easily go back to the original config?
-adam
alacrity024 is offline   Reply With Quote
Old 01-28-2004, 06:08 PM   #2
BAC5.2
Member#: 43996
The Aggressive (tm)
You don't know about it..
You could always pull the fuse. But they usually tie other things into that same fuse so something else won't work if the ABS doesn't. That's how we did it in Physics. We just pulled the fuse out of a cop car on "accident reconstruction day"
Chances are, if you are using this for track only, then the other things tied to the fuse won't be needed anyway.
Read the manual and see what else is tied in.
BAC5.2 is offline   Reply With Quote
Old 01-28-2004, 06:10 PM   #3
S.G.D
Member#: 36448
scoobymods.com has a how-to on it.
check it out. im thinking of making one too.
~SGD
S.G.D is offline   Reply With Quote
Old 01-28-2004, 06:32 PM   #4
alacrity024
Review Crew
Member#: 49476
sweet, found it.. thanks guys
-adam
Old 01-28-2004, 06:34 PM   #5
SonicYelloWRX
Member#: 36901
2007 RX-8
Brilliant Black
I made one using the scoobymods instructions, took me about 15min and it works perfectly.
SonicYelloWRX is offline   Reply With Quote
Installing an ABS on/off switch on an 07 WRX Desi_drifter395 Brakes, Steering & Suspension 11 10-10-2008 11:02 AM
ABS on/off using factory fog switch Motts Electrical & Lighting 9 04-26-2006 11:55 PM
Switch ABS on/off? 95hrdtp Brakes, Steering & Suspension 1 11-18-2002 11:37 PM
ABS on/off switch jamz New England Impreza Club Forum -- NESIC 23 01-31-2002 12:01 PM
ABS cut off switch WRXPOWER Brakes, Steering & Suspension 5 10-02-2001 04:05 AM
