Old 01-28-2004, 06:08 PM   #1
WReXinEfX
Member#: 20405
2000 OBS WRX Swap
Green
Default 02' WRX engine stronger than newer models?
Just read Sport Compact Car mag 02/04'
The section called "Swap an EJ20 into an old Subaru" points out that a WRX engine can be swapped into any old Subaru newer than 1995.
SCC wrote "You might want to shy away from engines newer than 2002 as we've noticed they tend to make a little less power(
about 10HP) than earlier engines."
Is this true?
WReXinEfX is offline   Reply With Quote
Old 01-28-2004, 06:11 PM   #2
Predator3
Member#: 50161
'05 WRX stage 2
San Remo Red
well most mags that tested the 04 got the same numbers as the 03 and 02, meaning 0-60 n 1/4 mile numbers
Predator3 is offline   Reply With Quote
Old 01-28-2004, 07:33 PM   #3
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
its probably cause the 02 's have a lighter flywheel and a more aggresive clutch ,but sometimes you get clutch shudder in the morning.03 and up have a heavier flywheel and a softer clutch with a safety valve so you can not drop the clutch and destroy your gear box.as far as the engines them self thay should be all the same.
tekfoc is offline   Reply With Quote
Old 01-28-2004, 07:41 PM   #4
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Sport Compact Car get facts wrong? nevar!
-Mike
MJU1983 is offline   Reply With Quote
Swap 2002 WRX Front End For Newer Model? WRXINTX Interior & Exterior Modification 10 09-24-2005 09:59 AM
JDM wrx engine stronger? Opinions needed. BlackSnake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-17-2005 05:56 PM
Are KYB AGX or Koni Yellows stronger than stock WRX struts? yobtah Brakes, Steering & Suspension 2 07-24-2004 02:46 PM
so someone said th 04 wrx engine is stronger than the 02/03 wrx engine... tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 65 10-25-2003 10:38 AM
Are Forester XT gears stronger than WRX gears? driggity Transmission (AT/MT) & Driveline 16 07-06-2003 10:54 PM
