Old 01-28-2004, 07:30 PM   #1
wond3rxB0y
Member#: 31764
2003 2016 STi
Default need help with gauges
i recently purchased the oem center pod with the boost, volt and oil temp...i dont need the boost since i have that on my steering mount already...what other gauges will be helpful to replace the boost (maybe a a/f ratio) ...also which will fit that oem center pod.. thanks
wond3rxB0y is offline   Reply With Quote
Old 02-03-2004, 12:22 PM   #2
awdman
Member#: 27962
2003 WRX Sedan
Blue, with more dings!
Default Modded car or no?
Have you or are you modding the car? EGT if yes.
How about a clock since you took that out?
awdman is offline   Reply With Quote
Old 02-03-2004, 12:26 PM   #3
awdman
Member#: 27962
2003 WRX Sedan
Default Sorry...
Factory gauges are 45mm I think. Omori makes gauges in this size but they aren't cheap. Then again, you did spend how much for that factory pod? Maybe funds are not a issue for you.
Sorry I had to make 2 replies...
Old 02-03-2004, 07:48 PM   #4
wond3rxB0y
Member#: 31764
2003 2016 STi
ahh i only paid 180 for the performance gauges from some fellow scooby owner from this site... i have not installed the gauges yet b/c i'm not sure what to replace the boost gauge???i only have a catback exhaust and a bov.. i'm getting the down/up pipe after winter soo let me know whats good to put on...
Old 02-04-2004, 02:13 PM   #5
awdman
Member#: 27962
2003 WRX Sedan
Default Now you're talking.
Okay, the UP/DP combo is going to mess with your exhaust temps, ECU and boost. Again I would opt for the EGT gauge.
Without the cats in your aforementioned pipes, the temp readings are going to increase. You can do the resistor mod for the uppipe, and ponyexpress fix for the rear O2 sensor but to insure
you aren't running lean a EGT gauge will allow you to monitor temps in front of the turbo so you don't cook it.
Off topic from your question but I think you should go for a reflash after or at the same time you do the pipe swap. That will eliminate CEL's and add more safety as to the possibility of running lean. Plus it's another 20-25 hp!
I'm doing the same mods except the cat back and I have Boost, EGT and oil pressure ready to go in whenever...
Old 02-04-2004, 06:20 PM   #6
kenchan
Member#: 15106
Intake temp guage.
kenchan is offline   Reply With Quote
Old 02-05-2004, 08:07 PM   #7
frostyTSM
Member#: 54361
2004 WRX Sedan
Java Black Pearl
Question
I have a 04 WRX and no boost guage. I'm interested in getting one to go in a better spot than the steering column. The guage pack for where the clock is would be nice, but it's a bit of an investment. Also, what use is a voltage meter?
frostyTSM is offline   Reply With Quote
Old 02-05-2004, 11:03 PM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
As far as "benefits", it allows you to see the current state of your battery's charge. It can alert you of potential issues/problems with your electrical system (irregular flucuations, declining voltage, etc.). A volt meter has helped warn me a couple of times in the past (once was a problem with the battery and the other was with the alternator......in my other vehicles).
- Kean
Kean is offline   Reply With Quote
Old 02-07-2004, 04:11 PM   #9
awdman
Member#: 27962
2003 WRX Sedan
Default Hey Frosty!
You can buy that center pod aftermarket now without the gauges!
DO NOT get it at the dealer!
Plus it will hold 52mm gauges if you buy an aftermarket version.
need help with gauges edel33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-18-2005 11:18 PM
Need help with gauges Pimp'n 2.5L Interior & Exterior Modification 11 05-21-2004 03:18 PM
Need help with gauge readings datwrx Electrical & Lighting 15 02-19-2004 01:17 PM
need help with gauge digitalmethods Electrical & Lighting 1 01-25-2004 08:33 PM
Anybody need help with gauge install Speedwagon Mid Atlantic Impreza Club -- MAIC 3 11-17-2003 07:44 AM
