Old 01-28-2004, 07:32 PM   #1
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
Default 1.8L Heads > 2L Block...doing something different
OK here's the deal. I have a 1.8L in an AWD Brighton. high mileage (140k ish). I wanna know if I can throw the 1.8 heads on the 2.0 block to raise the compression even more and if they'll bolt up. (for an NA setup)
MORE importantly...will the tranny match up even if I do a full EJ20/22/or 25 swap. Cuz I wanna put a new clutch in and don't wanna waste money on 2 clutches if I can use the same one?! Ya know.
Thanks if anyone has any clue/help.
WRX34
WRX34 is offline   Reply With Quote
Old 01-28-2004, 08:47 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
um
1.8 10 to 1
2.0 (the one sold in north america anyway) 8 to 1
you theroy has holes
the tranny will fit but if you make more power the cluthc may slip
Old 01-28-2004, 09:43 PM   #3
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
You want to put the 1.8 heads on a 2.0?
I think the 1.8 heads are the worst heads around.... with some of the lowet flow rates.
Old 01-29-2004, 12:16 AM   #4
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Um, your idea sucks
Ej18 heads = just about the worst heads in terms of flow. http://community.webshots.com/album/110209915vXVzdU
Old 01-29-2004, 12:31 AM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Originally posted by Kostamojen
Um, your idea sucks
Its kind of hard to see the difference but...
Your ej18s
http://community.webshots.com/photo/...10210534peVNqK
large port v6 heads
http://www.pbase.com/image/23502311.jpg
small port uk heads
http://www.pbase.com/image/23502317.jpg
Old 01-29-2004, 06:54 AM   #6
redwagon
Member#: 2181
2008 SpecB
That's interesting, my phase 2 EJ18 heads are completly different. They look just like the SOHC EJ25 heads, plugs through the valve cover etc...
redwagon is offline   Reply With Quote
Old 01-29-2004, 07:50 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Originally posted by Jaxx
um
1.8 10 to 1
When did the 1.8 get a 10:1 CR? It's been pulished as 9.5:1 since 1988.
Jay Storm
Old 01-29-2004, 08:58 AM   #8
redwagon
Member#: 2181
2008 SpecB
In my factory manual it says EJ18J = 10:1
Old 01-29-2004, 11:15 AM   #9
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
as does mine
and the 88 1.8 (ea) is nooooot the same as a 93 1.8 (ej)
Old 01-29-2004, 11:52 AM   #10
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
my EJ18 is a 9.5:1
Old 01-29-2004, 02:58 PM   #11
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
Well I was just trying to setup something different LOL. Oh well! I know a lot of Honda motors (like mini-me) etc. are able to raise/lower compression by doing this so I fig'd I'd ask since I know NOTHING about the EJ18. Thanks for the pics too, very big difference yes, but I was just seeing what wierd options I have as to play with compression on an NA scale, flow would affect the compression I'm sure which is why it's smaller heads = less flow = more compression? Or not...
As far as clutch slipping...I have a stock WRX clutch with like 1k miles on it for dirt cheap, which is my biggest concern right now as to if that will bolt up and it all looks like it will in theory! We'll see I guess! I think most Subaru motors will bolt up to it. Any thoughts on changing or keeping the gear ratios/final drive/diffs/etc out of the 96 EJ18 Brighton?
I think we'll drop my EJ20 from my WRX into the Brighton and maybe throw an EJ22 into the WRX. Any comments? Or you think going a built up 2.5 NA would be better?
Thanks again guys/gals.
WRX34
Old 01-29-2004, 03:00 PM   #12
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
Hmmm...where did you get these/what are they off of? What is your current setup with this and yeah...more info the better. If you posted b4 lemme know and I'll search or if u have the link handy that's cool too.
WRX34
Old 01-29-2004, 03:40 PM   #13
WRX34
Member#: 13364
1996 GM8 caged,
99 V8 RSTi, 11' FXT
http://wac.addr.com/auto/obs/turbo/ejcalcs.html
After looking here I think I might keep the tiny 1.8 block and drop a 2.0 or maaaybe 2.2 head onto it, then put a pos stock turbo from my WRX in! Get around 8.5-8.7 compression maybe after that!?! HEHEHE BOOST! That could be fun and lightweight to boot!
WRX34
Old 01-29-2004, 03:47 PM   #14
totoherbs
Member#: 7321
.... 122 IggPoints
WRX34
The 2.2 SOHC head is the same small thing as the ej18s. SOHC RS heads will flow good, more then the wrx heads.
Old 01-29-2004, 07:15 PM   #15
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Is that the MY97 EJ18?
Old 01-29-2004, 08:19 PM   #16
redwagon
Member#: 2181
2008 SpecB
Nope, it's MY'00.
Old 01-29-2004, 08:27 PM   #17
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
good god!! they still made EJ18 for MY00??? I always thought they discontinued it since '97 and just used 2.2s. EJ18s do have the thickest side-walls though, 9mm as I was told.
-Vic
STi-Nismo Dood is offline   Reply With Quote
Old 01-29-2004, 08:39 PM   #18
redwagon
Member#: 2181
2008 SpecB
It was still available here in Taiwan until MY'01, it may still be in Japan or some other market.
This is an EJ25, but my motor looks exactly the same:
http://www.specialtyauto.com/_border...DSUBENGINE.jpg
Old 01-29-2004, 10:34 PM   #19
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Wierd, whats the hp rating for that EJ18?
Old 01-29-2004, 11:03 PM   #20
redwagon
Member#: 2181
2008 SpecB
In the book it's rated at 120ps, I forget the torque number right now.
Are there any numbers on the heads to identify them? I'm really curious to know if these are common with another motor. Mine are serial numbered 572368 & 9 respectively, dunno if that makes sense to anyone.
(edit)
Here we go:
120ps @ 5600
16kgm @ 4000
10:1 compression
Bore x stroke 87.9X75.0
It's phase 2, OBD-II compliant
By the look of it, it should be a straight swap with a late EJ25, plugnplay.
Old 01-29-2004, 11:51 PM   #21
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
my motor is for OBD-I
10 HP for every .5 of compression increase... hmmm... at least theres better flow. hehe..
now I see how UDSM Fords do 12.5:1 and uhh yeah...
what's zat I've learned today? times doesn't make much of a difference from the intuition or ambition that you wanna do to your motor...
hey red, are u living in TW?? How'd you know about NASIOC?
-Vic
Old 01-30-2004, 12:14 AM   #22
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
no that won't work
the clutch must match your transmission
all the n/a subarus sold in the US have push cluthces the wrx is a pull clutch
Old 01-30-2004, 12:32 AM   #23
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
is the legacy turbo a pull clutch also?
Old 01-30-2004, 01:17 AM   #24
RebelINS
Member#: 2953
2000 Impreza 2.5RS
2005 Impreza WRX STi
They didn't make an EJ18 in the US in 2000, The smallest Impreza motor in MY00 was the EJ22. The EJ18 in the US never went above 9.5:1 CR, either.
If you are going to stick with NA, but plan on doing an EJ25 swap, you should swap the trans two. Yours is geared for gas mileage (3.90 final drive), which I am sure would feel really slow with a NA EJ25. Not to mention that the RS transmission is hydraulically actuated, rather then cable driven.
-Wes
RebelINS is offline   Reply With Quote
Old 01-30-2004, 01:26 AM   #25
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
(edit)
Here we go:
120ps @ 5600
16kgm @ 4000
10:1 compression
Hmm, interesting... I would think it would be more related to the more recent N/A EJ16's and N/A EJ20's from over seas rather than the EJ25 though.
N/A setup with a 2.2L block and 1.8L heads (reliability questions) KillerBumbleBee Normally Aspirated Powertrain 4 08-24-2012 03:02 PM
My headlight mod- I tried to do something different cky211 Interior & Exterior Modification 54 05-21-2004 02:19 AM
1.8L vs 2.2L, what do you think? evorev Normally Aspirated Powertrain 26 01-12-2004 11:59 PM
('93-'01) Differences between 1.8L & 2.2L AWD Impreza 95+ Subdued Impreza Forum 26 05-13-2003 08:40 AM
