#1 |
Member#: 6964
Vehicle:2001 impreza pearl ridge blue |
can anyone tell me what is the difference between top and side feed injectors, i know the obvious, side and top duh,
i am asking like, why was it done, any differnence between them, which is better. i need all the info on them as much as possible. can i fit sti injectors on the top feed one? thanks
#2 |
Member#: 177
NWIC
Vehicle:The 93 Imp W/EJ20K flat black |
there is yet another the new STI had side feed injectors too but they should probblay be called bottom feed as the are differnt thatn the other side feed
#3 |
Member#: 7321
NESIC
Vehicle:.... 122 IggPoints Work... ahhh... so tired. |
Can you fit top feed jdm STi 565 injectos in a side feed no... not with out changing the rail. The usdm STi sidefeed are 480cc, and the wrx are 420cc.
#4 |
Member#: 6964
this is what i am doing, i have a jdm engine which is top feed, i was wondering if i can use the jdm sti injectors with mrt fuel rails.
#5 | |
Member#: 7321
NESIC
Im not a fan of aftermarket fuel rail...
#6 |
Member#: 6964
so u are telling me fuel rails are bad, ok
does anyone know if the sti injecters fiton mrt fuel rails, and the differences with the top and side injectors? |
| Thread Tools | |
| Display Modes | |
| differance between top and side ffed injectors? | mywrxspeed | Factory 2.0L Turbo Powertrain | 6 | 11-24-2009 12:45 AM |
| difference between top and side feed injectors | mnkypsycho | Factory 2.5L Turbo Powertrain | 3 | 11-01-2003 02:58 AM |
| quick question, what's the difference between 18mm and 20mm sway bars? | popnGEAR | Brakes, Steering & Suspension | 17 | 05-15-2002 02:20 AM |
| What's the difference between AWD and 4WD? | Fubaru | Newbies & FAQs | 19 | 05-03-2001 10:15 AM |
| what is the difference between V4 and V5 wings | Cata | Vancouver Impreza Club Forum -- VIC | 1 | 09-28-2000 08:47 PM |
