Old 01-28-2004, 09:49 PM   #1
Wedge
Member#: 2279
2000 Slingshot/99RS
Pastelito Racing / SFSOC
News Cometic HG fit on EJ22T Block Pics
Thought I'd post a couple shots on the fit of the Cometic HeadGasket for the EJ25. As you can see, it's not an exact fit, but it should still work. If you look closely, you can see the o-ring design of the Cometic HG.
And here's a shot of it placed on the EJ25 heads.
(Block rebuild is 'almost' done!)
Wedge is offline   Reply With Quote
Old 01-29-2004, 04:00 AM   #2
STi-Nismo Dood
Member#: 4149
MY93 ImprezaRA Sedan
GC8.6 Aspen White
are those headgaskets going to promote more boost?
STi-Nismo Dood is offline   Reply With Quote
Old 01-29-2004, 08:15 AM   #3
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Why didn't you buy the gaskets in EJ-22T form?
-Tod
todnar is offline   Reply With Quote
Old 01-29-2004, 09:03 AM   #4
Wedge
Member#: 2279
2000 Slingshot/99RS
STi= Yep. Thats exactly why I chose these.
todnat= Simple, more boost without having to worry about blowing a headgasket.
Old 01-29-2004, 09:10 AM   #5
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
You think the coolant passages in the block is going to be a problem since the gasket covers some of them?
latinskllz is offline   Reply With Quote
Old 01-29-2004, 09:18 AM   #6
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Ok.I just thought it was better to match bore size. What thickness did you get? The HP series is available for the EJ-22T in
.030",.036",.043" and .057".
-Tod
Old 01-29-2004, 10:38 AM   #7
Wedge
Member#: 2279
2000 Slingshot/99RS
Specs in HG : EJ25 / 100mm / .043-HD /
Old 01-29-2004, 10:41 AM   #8
Wedge
Member#: 2279
2000 Slingshot/99RS
Thumbs up
OK! PROGRESS!
I just got a call from the shop this morning! The shortblock is complete! I am using a brand new EJ22T oil pump, and water pump (which I think I'm going to have to change to the EJ25 water pump, dunno if it'll align correctly with my radiator)
Also, I don't know if I "need" to replace the headbolts. I looked through all the service manual, and couldn't find anywhere where Subaru specifies to have them replaced.
Here are the pics!!!
Old 01-29-2004, 10:46 AM   #9
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Old 01-29-2004, 10:57 AM   #10
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Cool! I'm actually worried about my CR being to low on my build with the DOHC heads.
Where did you get the pistons from?I'm thinking of getting a set made so I can get my CR to be 9:1.
-Tod
Old 01-29-2004, 11:09 AM   #11
Wedge
Member#: 2279
2000 Slingshot/99RS
They're Ross Pistons, custom made since I had the walls bored. And I had them ordered 8.5:1 also.
Old 01-29-2004, 11:25 AM   #12
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Thanks. I was on their site yesterday looking around.May I ask what they charged for the pistons and rings.And what brand of rings did you go with?
-Tod
Old 01-29-2004, 01:21 PM   #13
Wedge
Member#: 2279
2000 Slingshot/99RS
I paid $580 for 4 custom pistons, and total seal rings to go with it. I do have a wholesale discount though, so dunno how much retail would run.
Old 01-29-2004, 02:19 PM   #14
todnar
Member#: 24915
2000 L Wagon Aspen
93 L Wagon Aqua
Thanks.
Good to now they will have an idea about what I'm talking about with the 2.2 when I call them.I need to get my heads back from the machinist so I can cc them again after the combustion chambers got worked on before I do though.
My Cometic gaskets in EJ-2.2T form were identical to the ones that came with the Subaru gasket kit for the 98 2.5L except for bore size. I notice you have a 2000 and the SOHC heads.It looks like the 2.2 gasket would have been pushing it with those combustion chambers.Ecspecially if you had them worked on.
I'll check the coolant holes on my block compared to the gasket when I get home tonight.I'm pretty sure part of them were blocked just like your pics show.
Later, Tod
Old 01-29-2004, 04:36 PM   #15
Scoobyslack1
Member#: 2780
junk yards rule!
Project FrankenSTien
Question
Vic, you got the same #?
I'd like to call you and talk about the gaskets.
I'll be pulling my motor soon to do the head swap
Scoobyslack1 is offline   Reply With Quote
Old 01-29-2004, 08:20 PM   #16
Wedge
Member#: 2279
2000 Slingshot/99RS
PMing you Alan.
Old 01-29-2004, 08:32 PM   #17
Wedge
Member#: 2279
2000 Slingshot/99RS
Some more pics of the engine, MORE PROGRESS!............looks MUCH better now!!
EJ22T Block Pics -- ATTN Eric seven881 Normally Aspirated with bolt-on Forced Induction Powertrain 79 05-19-2009 02:35 PM
EJ25 DOHC on EJ22T block WRXwannbe Normally Aspirated Powertrain 17 03-11-2007 10:41 PM
Most documented Dynoed Hp on ej22t block? reddevil Proven Power Bragging 17 03-27-2006 10:51 PM
2.5L DOHC heads on EJ22T block 4wheelflyer Subaru Conversions 35 11-27-2003 01:37 PM
99 2.2 vs 2.5 heads on EJ22t block mikeje Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-21-2001 12:28 AM
Message Board Statistics All times are GMT -4. The time now is 04:57 PM.
