Old 01-28-2004, 11:47 PM   #1
vile
Member#: 32371
'02 t-rex wagon
platinum
Default 12V impact wrench?
i remember someone mentioning that they are using an impact wrench from harbor freight. it operates off of the 12v car battery
i thought this might be a good find for u car nut....something to keep in ur car.
http://www.harborfreight.com/cpi/cta...emnumber=36175
anyone used this before? any good? enough juice to take off lug nuts on tires?
vile is offline   Reply With Quote
Old 01-29-2004, 04:04 AM   #2
WRXVII
Member#: 15854
VF34'd...
I've tried it on my car... it's got enough juice to take off lug nuts as long as it's not tightened super tight. $20 from Walmart!
WRXVII is offline   Reply With Quote
Old 01-29-2004, 05:56 AM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
The one I got from Wallyworld works surprisingly well...It even did struts...it took a couple minutes, literally, but it broke 'em loose...it did an axlenut, too...and an ALK...
Old 01-29-2004, 11:37 AM   #4
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Get this instead, for $99. I got one for the rally car, but it's so good my mechanic uses it around the shop instead of dragging out the air tools. It's quiet, powerful, and has lasted 2 years of daily use, even with a crappy NiCd battery.
Jon Bogert is offline   Reply With Quote
Old 01-29-2004, 11:46 AM   #5
vile
Member#: 32371
'02 t-rex wagon
platinum
danx guys, i think i'll pick one up this weekend
hey john, you never mention what that thing is....no links? no name, no label, no specs etc.
*edit (in re: to clicking on pic) - "they call me nooob" (think flipper)*
Old 01-29-2004, 11:49 AM   #6
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
Click the pic.
Old 01-30-2004, 03:07 AM   #7
WRXVII
Member#: 15854
VF34'd...
I just ordered that impact gun!
Is it strong enough to take the transmission oil drain bolt?
Old 01-30-2004, 03:15 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
The transmission drain bolt is only to be torqued to 32.5ft-lbs.
Don't strip it out.
Old 01-30-2004, 09:01 AM   #9
grindMARC
Member#: 23547
13 Focus ST
Blurple
I've been waiting on delivery of this CORDED one for about a 10 days now.
http://www.harborfreight.com/cpi/cta...emnumber=45252
That cig lighter version only has 10-20 blows per minute. The above version has 2400?!? I guess if you don't have a garage or an outlet near your car the cig lighter ver is the way to go (or the battery powered).
If you add a socket set to the order and get it over $50, shipping is free... it just takes a while.
grindMARC is offline   Reply With Quote
Old 01-30-2004, 01:41 PM   #10
leecea
Member#: 37359
2003 WRX
Before anyone buys the 12v impact wrench, read the instructions online. It is only designed for emergency use - presumably for someone who gets a flat and can't undo the wheel nuts. Plus it works in a different way than "real" impact wrenches. They describe how it will spin up for a while, then whack the nut with a single impact. This can be repeated by pulling the trigger again... or something like that.
leecea is offline   Reply With Quote
Old 01-30-2004, 04:28 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
I have used mine, bought at Wallyworld for ~$20, almost to destruction(time for a new one, I think). It does work a bit different than an air tool as the number of 'blows per minute' is low...and it is NOT a heavy duty tool by any standard, but it DOES work and it has a LOT more power than I ever expected....and I'm a mechanic used to air tools....a good $20 tool to have, even if it saves your ass only once and breaks...save your receipt from Wallyworld, and get another one....I've used mine quite a bit
Old 02-23-2005, 04:00 AM   #12
yarikoptic
Member#: 56008
2001 Outback LL Bean
white
Default through adapter
sorry to bring the same story up from heaven
What is the power in W of this beast? would it be possible to run it in emergency from cigaret lighter -> 110V transformer of any reasonable power ability?
yarikoptic is offline   Reply With Quote
Old 02-23-2005, 04:02 AM   #13
yarikoptic
Member#: 56008
white
oops - my bad - I need to go to sleep :-)
# Volts: 120
# Amps: 7
120x7=840 is way too much :-)))
Old 02-23-2005, 04:28 AM   #14
outbackwbeer!
Member#: 64060
98 lifted FOZ M/Ts
glacier white
Default snap-on 14.4v cordless
I bought a Snap on 14.4v cordless impact 1/2" drive 250ft lbs. torq.
came with nice plastic case/charger 110v/two batt packs/flexhead flashlight.
You can get a 12v plug in charger too.
It's bomber! and quiet! yeah it cost me a few bills ,but I wrench for a living.Great for service calls/home.
outbackwbeer! is offline   Reply With Quote
Old 02-27-2005, 04:31 AM   #15
InfamousDX
Member#: 25413
I have that one... it's great for struts, lug nuts... it's pretty versatile considering it was so cheap.
Old 02-28-2005, 08:27 AM   #16
WRXVII
Member#: 15854
VF34'd...
This one is amazingly strong. I've used this during spring install without any problem. Best $99 I spent on tools.
Old 03-02-2005, 07:20 PM   #17
ExitVisa
Member#: 15276
2003 WRX
I clicked your link and got this: "The Specifications for this item are not currently available online, or the item has been discontinued."
ExitVisa is offline   Reply With Quote
Impact Wrench and Impact Socket Set Andrew Non-Subaru Stuff 3 07-13-2007 07:13 PM
Makita 12V Impact Driver ejh25 Off-Topic 13 01-07-2005 09:48 PM
F/S: 12V portable impact wrench. See pic. $30 Brand new SoBaLoWRX Tri-State Area Forum 0 08-28-2002 11:40 PM
Gonna buy the 12vdc impact wrench RidinLow General Forum Archive 4 11-27-2000 01:55 AM
12 VDC impact wrenches - any good? Mike Smith General Forum Archive 9 11-22-2000 09:40 AM
