Old 01-29-2004, 07:59 AM   #1
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Default Possible UTEC hack?
Would it be possible to bypass the o2 sensor wires on the utec harness so it goes straight to the ecu. Then you could wire in a true wideband right to the UTEC. Then the logs on the UTEC would have a true AFR capabiliteis. The only reasons this wouldn't work is if the UTEC actually uses the input and the voltage input is not in the UTECs range.
A techedge setup for this would only cost about 300 since you don't need the display or logging capabilities/
LiquidForce is offline   Reply With Quote
Old 01-29-2004, 02:08 PM   #2
SleeperWRX
Member#: 8179
the utec reads rich under 12:1 (i think its 12:1) because the stock sensor is only accurate down to that point. So the new sensor would accurately read richer than 12:1 but the UTEC would still just say rich.
good idea tho if you could convert the voltage to the same range as the stock sensor...and there was a way to make the UTEC show the values below 12:1
SleeperWRX is offline   Reply With Quote
Old 01-29-2004, 02:44 PM   #3
Cosmo
Member#: 31777
2003 Subaru WRX
Yellow
I'm pretty sure the UTEC can display whatever the A/F is. The drawback is in the semi-wideband O2 sensor the WRX comes with. The TXS Tuner comes with a wideband O2, and the UTEC can read that accurately.
Cosmo is offline   Reply With Quote
Old 01-29-2004, 03:09 PM   #4
LiquidForce
Member#: 12811
2002 2.5l Wrx
If this is a problem then I could have Autlogger add a column to the logs that is derived from the voltage.
Old 01-29-2004, 03:11 PM   #5
GRoceryTurbo
Member#: 9407
02 WRX
platinum silver
I asked Nathan one time about trying to log A/F with the techedge I had and he said it wouldn't work, that's all I asked.
GRoceryTurbo is offline   Reply With Quote
Old 01-29-2004, 11:07 PM   #6
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
I don't see any reason why this wouldn't work. If you have the calibration for the voltage, it's pretty simple I would think. The only caveat might be that it has to be in the same voltage range as the stock sensor (hopefully the voltage would be too high which can be adjusted with resistors of course). Assuming the amperage is very close so you won't blow out the circuitry of the UTEC as well.
Maybe you can call it the Minnow!
mtb_dude is offline   Reply With Quote
Old 01-30-2004, 11:33 AM   #7
LiquidForce
Member#: 12811
2002 2.5l Wrx
Does anyone know the specs (voltage and amperage) for the stock 02 sensor? Tech-Edge has the information for their widebands but I can't dig it up for the stock one.
Old 01-30-2004, 12:13 PM   #8
parid
Member#: 16336
2002 WRX Wagon
I'm pretty sure the stock sensor is 0-1V and a most wideband o2 sensors are 5-0V. Check out the LM-1, it has an analog narrowband output (the 0-1v range). It's only 350 bucks.
Any reason why the TurboXS TUNA is ruled out? The knock functionaly makes it worth the extra money IMO.
parid is offline   Reply With Quote
Old 01-30-2004, 12:34 PM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The stock sensor is a wb (or near wb) sensor. It has two outputs and the AFR's need to be calculated from them. You can't just simply hook up a single voltage to the dual wires and get it to display correctly.
Even if you could, you'd have to hack the software/firmware in the UTEC itself to display anything out of it's normal range.
I think their TurboXS Tuner is your only option to get true WB input.
Old 01-30-2004, 01:44 PM   #10
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
That's right. the UTEC is getting the A/F from the front wideband sensor. The reason (partially) the UTEC reads rich is that the sensor is inaccurate under boost; the exhaust back pressure screws with the reading.
If you could get another wideband after the turbo and connect that one to the UTEC (and rout the original to the ECU), the UTEC needs to be told the signal is OK and display below 12:1. 'Course, this assumes the UTEC intecepts the sensor input and can convert it for the ecu (or for itself and lets the orginal signal go to the ECU). I think it is really reading off of an ECU output.
Tom
SlideWRX is offline   Reply With Quote
Old 01-30-2004, 02:27 PM   #11
LiquidForce
Member#: 12811
2002 2.5l Wrx
That's what I was suggesting. The point you bring up about wether the signal has already been processed by the ECU before it gets to the UTEC would make it impossible. I don't think that is the case though looking at the harness.
Old 01-30-2004, 02:32 PM   #12
LiquidForce
Member#: 12811
2002 2.5l Wrx
700 reasons. If this would work it would cost less than 300. If you are capable of putting a DIY kit together its less than 200.
Old 02-02-2004, 04:23 PM   #13
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
Lets not let this fall off please... I have a techedge, and an LM1 that allows me to see A/F realtime in the deltadash, I wonder if some of the UTEC loggers that have been written could import this information? Time to head over to wrxhackers I think
DarthChicken is offline   Reply With Quote
Old 02-02-2004, 04:59 PM   #14
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Tom
Thats false information. The ECU's Rom file calibrates the Sensor for exhaust backpressure. The Sensor itself has a bottom edge limit of 11 to 1. The Sensor is very acurate up until that point.
I would be interested in a Utec logger that would pick up the serial input from a second com port to read WB data into the logs. I have a Rom file for the LM1 Wideband that gives you that output on the Serial. It works with Delta dash and the Flash program for ECUtek.
Clark
AZScoobie is offline   Reply With Quote
Old 02-02-2004, 05:37 PM   #15
Jon [in CT]
Member#: 2992
02 WRX Sedan
This, also, is wrong. The UTEC completely ignores the signal from the front A/F sensor. If you tell the UTEC to log it, then the UTEC will use the same method as DeltaDash to acquire that info - it interogates the stock ECU.
Jon [in CT] is offline   Reply With Quote
Old 02-02-2004, 07:39 PM   #16
SlideWRX
Member#: 3803
07 Mustang GT
Tom
Which is what Jon says above. I implied, but did not explicitly say in detail that the UTEC gets A/F from the front sensor, through the ECU. I apologize.
Clark
Huh. One wonders why the UTEC does not display this far down. It has been asked here and elsewhere why it displays 'rich' below ~12:1, and the most common (and undebated - that I had seen) answer was excessive back pressure. learn something new everyday.
Tom
Old 02-02-2004, 08:31 PM   #17
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
So what this says is that a seperate interface will have to be written. The UTEC will NOT log, so we need something along the lines of a utec logger type of interface. Somethat that will pull information from both the UTEC and a seperate interface (like the labjack).
Old 02-03-2004, 11:44 AM   #18
AZScoobie
Member#: 8785
netcom.com
Tom
Tom. Because the System is a Closed loop/ open loop system the AF sensor has one job in life. To measure 14.7 to 1 for closed loop operation. It does that with super acuracy. The sensor reads down to 11 to 1 and to that point it is very acurate. It will read with my LM1 wideband until 11.2 to 1 where the LM1 reads 10.8 to 1. At all other times they are spot on or with in .1. The only thing that I can think that would skew the readings would be a wild EGT difference over a stock car (not common) or a wild pressure difference. I have that wild pressure difference in my turbo setup and the readings seem to be spot on.
Cya
Clark
Old 02-03-2004, 02:36 PM   #19
LiquidForce
Member#: 12811
2002 2.5l Wrx
It would be easy to make my Autologger app merge wideband data from another serial port. I already have the wideband column in the new version for the "Tuna". It would only be a problem for people with only one serial port.
My question though is if you already are using a delta dash , don't you have more complete logging anyways?
Old 02-03-2004, 02:43 PM   #20
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
It keeps folks from having to buy the deltadash for one, and another is that it allows you see exactly which cell the UTEC is in immediately without having to go through the hassle of figure out load vs. MAP)
FS: (HR) Subaru STi and WRX parts - exhaust, dp, uppipe, FMIC, UTEC, CAI, etc. azrakain MAIC Private Classifieds 71 06-02-2011 08:21 PM
possible to hack a windows 2000 server account without changing password? plunk10 Off-Topic 21 01-10-2008 10:41 AM
Napster To Go...Possible non-time consuming Hacks? Hotrodguru Off-Topic 2 07-25-2005 02:16 PM
WTB locally: FMIC, UTEC, suspension, brakes, possibly rims and tires drifterx North West Impreza Club Forum -- NWIC 6 10-20-2003 05:49 PM
Possibly going from Unichip to UTEC - ?'s PadreWRX Engine Management & Tuning 14 01-28-2003 01:42 PM
