Old 01-29-2004, 12:38 PM   #1
99WRXEJ20
Member#: 34545
1999 GC8
74f
Default Water pump part # for a EJ20G?
will the us spec one work or will one work from a tubo legacy? Or does anybody have a part number that will work?
thanks
99WRXEJ20 is offline   Reply With Quote
Old 01-29-2004, 01:15 PM   #2
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
I honestly would get a legacy turbo waterpump with the neck because the wrx one has three coolant nipples on them where two you won't need if you don't have a oil cooler and the other pipe that goes up the front of the block torwards the back and crosses over to the passenger side and connects to the water pipe the wrx has attached on the passenger side manifold.
I'd have to wait until i go home for the part numbers...
latinskllz is offline   Reply With Quote
Old 01-29-2004, 10:03 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
I just looped the 2 extra holes back to eachother. The part number is 21111AA026. Don't forget the gasket 21114AA050.
Brent
scoobyimprza is offline   Reply With Quote
Old 01-30-2004, 12:16 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
use the legacy turbo pump.. Noah (works for cobb) used it on his ej20g..
Water pumps part numbers bugeyes Built Motor Discussion 2 04-07-2008 10:19 AM
ej20g water pump part no? AsphaltsCry Subaru Conversions 6 11-30-2005 07:00 PM
Supra TT fuel pump part # PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-30-2003 11:28 AM
Does anyone know the part # for the secondary air filter box gasket for a '99 dandbest Technical Forum Archive 4 07-16-2000 02:08 PM
Part # for STi parts Greg 99 Technical Forum Archive 1 05-10-2000 06:58 AM
