#1 |
Member#: 19897
I just got my rex back from the body shop (they replaced my right QP), now I am getting the following code:
P0447 Evaporative emission control system vent control low input What does it mean, is the car safe to drive, and is it something I can fix easily myself?? Thanks
#2 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
You have more damage to be repaied....you have a leak somewhere I would guess....
#3 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
The evaporative charcoal canister and associated hoses are located under the right rear of the car, so if there was damage and repair work in that area it's likely some of those components were affected. It's not dangerous so you can drive the car around, but it will need to be fixed. It's easiest to inspect the stuff under there with the car on a lift.
#4 |
Member#: 20315
NESIC
Vehicle:1997 Impreza L hunter green |
I had body work done to the rear as well and got an evap code also. Turned out one of the pipes that runs to the charcoal canister was rubbing on the strut and had a small hole in it. I patched it up and code never came back.
| Thread Tools | |
| Display Modes | |
| Before and after 01 impreza, body work | vvRX7 | North West Impreza Club Forum -- NWIC | 27 | 04-01-2010 04:22 PM |
| My 1998 L after some body work and paint :) | wjc04wrx | Member's Car Gallery | 29 | 12-24-2006 02:01 PM |
| Driving lights won't work after body shop removed and painted bumper? | PhilJensen | Electrical & Lighting | 1 | 09-01-2005 04:29 PM |
| Re-mount Turk satellite radio antenna after body work? | C-daleRidr | Car Audio, Video & Security | 1 | 03-08-2005 11:54 AM |
| Cleanup after body work?? | donjuan | Service & Maintenance | 2 | 03-20-2004 10:53 PM |
