Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 01-30-2004, 09:33 AM   #1
Charlton
Member#: 43038
2002 Forester S
Default oil pan crush washer question
Will it hurt to reuse the crush washer on the oil pan more than once? I was wanting to change my oil this weekend but I don't feel like going to Subaru to get the crush washer. Can I do it just one time?
Charlton is offline   Reply With Quote
Old 01-30-2004, 10:59 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Can you? Sure, nothing stopping you. Will it leak/weep? Possibly.
Brian
Old 01-30-2004, 11:20 AM   #3
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
Well, i suppose it could depend on how tight you "crush" it. I reused mine 3 times, only to have it start leaking after the 3rd time (that was because i didn't realize quite what the crush washer was for...)
Old 01-30-2004, 12:53 PM   #4
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Cool trick:
Get our your oxy torch. Heat up your used crush washer until it's glowing red. Let it cool slowly.
You've now annealed your crush washer and its soft again. Of course, you've already crushed it thinner, so you couldn't do this forever....
Anders
anders8 is offline   Reply With Quote
Old 01-30-2004, 02:22 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
It's like $1 . Why would you go to that much trouble for $1 ?
Brian
Old 01-30-2004, 02:44 PM   #6
anders8
Member#: 26658
1 Love Grassroots
Well, I have ten of them sitting on the shelf, so I don't know!!!
However, I can imagine one scenario: Changing oil late at night. Rally next morning. All stores closed 7 hours ago.
Old 01-31-2004, 02:14 AM   #7
Mikkito
Member#: 46426
2015 No longer scoob
because I suck. :(
Man, I didn't even have to pay for mine...
I can't imagine why anyone would rather toast it and reuse it than just get some when they're out and about...
Mikkito is offline   Reply With Quote
Old 01-31-2004, 01:44 PM   #8
rexaroo
Member#: 35732
2002 WRX Wagon
Get a Fumoto drain valve. $22.95 and you'll never need to change the crush washer again. Makes oil changes a lot less messier too. Fits all Subies so if you buy a new Sube, you can take it off and re-install it!
rexaroo is offline   Reply With Quote
Old 02-01-2004, 01:10 PM   #9
rick-l
Member#: 33868
2003 wrx
srp
Brian
What if the dealer is 20 miles away and you work during their buisiness hours? I haven't found the part at the FLAPS. Crushed three times so far no leakage.
What do Jifffy lube type stores do?
rick-l is offline   Reply With Quote
Old 02-01-2004, 10:58 PM   #10
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Just remember that a crush washer is not only there to help prevent leaks between oil changes. It also helps prevent thread damage in the oil pan. Just buy a handful of them so you don't have to worry about it. Personally, I like to do the job right and see no reason to skimp on such an inexpensive item.
Kean is offline   Reply With Quote
Old 02-02-2004, 12:37 AM   #11
rick-l
Member#: 33868
2003 wrx
srp
Anyone see why the solid copper crush washers that Bobby Bosch scatters through European fuel injection systems like confetti wouldn't work. Now what size are the inner and outer diameters of the washer. These you could get a handful of for a couple bucks.
Old 02-02-2004, 07:12 PM   #12
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Anders - That trick works with copper crush washers. The OEM Subaru drain plug gasket is (I think) steel, and has a "D"-shaped cross section that physically smushes when it's tightened. So it can't be easily annealed, and even if it were, it wouldn't restore the gasket's sealing capability.
rick-I - I've used many different kinds of gaskets around Subaru drain plugs -- copper, rubber, plastic... The OEM one seems best but the others can work if they're all you have. The size you need is 20mm inner diameter. I've used some standard-sized drain plug gaskets before, too... can't remember if they were 3/4" or 13/16".
I wouldn't use a copper washer for the oil drain plug because they're meant to seal against two machined flat surfaces, and the Subaru oil pan isn't a flat machined surface. In a really tight pinch it would probably be better than nothing at all if you torqued it down hard, but still...
vrg3 is offline   Reply With Quote
Old 02-02-2004, 11:27 PM   #13
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
I've reused crush washers repeatedly and never had a leak. Just check it regularly and make sure to replace it next time.
Mike Wevrick is offline   Reply With Quote
WTB Oil Pan Crush Washers online? REXMASS New England Impreza Club Forum -- NESIC 3 06-15-2004 09:16 AM
Stupid oil plug crush washer question. LinuxGuy Service & Maintenance 12 10-19-2003 12:13 PM
Subaru Oil Filter Crush Washers *Free* Hank3 Private 'For Sale' Classifieds 5 10-06-2003 11:27 PM
Cantex/Forest re-oil filter/crush washers Tex-WReX Texas Impreza Club Forum -- TXIC 0 08-01-2002 09:32 AM
Oil plug crush washers? yakker Technical Forum Archive 18 06-09-2000 06:39 PM
