Old 01-30-2004, 11:04 AM   #1
Hummer
Member#: 31892
2004 STi
Default Xede 93-94 stage one MAP in the STi and dyno
This is a long story so bear with me. I woke up at 5 am and left the house about 6:00 am for St. Louis. 10:00 am and I am at Axis in St. Louis. FIRST things....Ron busted his butt all day on my car and he did a great job. I highly recommend them. Now back to the story. Ron pulled my IC, Intake, and turbo. He then ported the waste gate on the turbo. Next was pulling my egt probe from the down pipe and putting it in the manifold. After that he hooked up my turbo gauge and corrected a miswiring of my gauges which was killing my battery. He then reinstalled the turbo and downpipe. He got all of this done in less than 3 hours and then we had a delightful lunch.
2:00pm Alrighty then....now is where the REAL fun started. Ron pulls out the XEDE and the color code instructions from Vishnu for the pin outs were wrong. Vishnu would not answer the phone today so we{Ron} were on our own. He got them all wired correctly the first time. The next step was was to fire it up. Vishnu did not load the STi stage 1 maps{or any maps for that matter}. Every map was zeros. Ok...no problem...Mike and I go to his place for internet access and he downloads the sti maps from the Vishnu site and burns them to disk. We then go back to the shop.
4:00 pm Got the maps, put them in the Xede. The car is running......good sign. Time to head to Ron's other place for the dyno.
4:30 pm Oh look outside...it is so pretty....it's snowing! This is getting exciting with me, the STi and the stock tires. I don't know where I am and it's snowing....Yea!
5:30 ish {losing temporal cohesion} OK...On the dyno we go and I have 200 WHP. SWEET! Ron scans the info and I am running 9 PSI max boost. Hmmmm.............Vishnu is still not answering calls.........Ron determines that the STi stage one 93-94 boost map is horribly wrong. Ron then had to fix it.
7:30 ish 15 pulls on the dyno. The car is tuned and the throttle body is hot.. Nobody wants to wait around an hour to cool and do it again.
8:00 ish leaving Illinois and heading home {the roads were pretty clear}.
11:59 Home - 3 beers, 30 emails, and off to bed.
Here is the dyno info......Dyno Dynamics Dynamometer
Max WHP was 257
Max Torque was 280
This was a 3rd gear pull running 93 reformulated winter gas.
The dyno is here. http://home.kc.rr.com/cerberus/xede_and_dyno.htm
The max boost on the final dyno was 15 psi. It might need more tweaking or it might be the heat. I should know soon. I didn't push it on the way home because of the weather and I was tired.
Edit: I took the car out this morning and I hit 16.5 PSI in 3rd. There is a noticable difference with the XEDE in power and torque.
Thanks again Ron and Mike! They know subies!
Hummer is offline   Reply With Quote
Old 01-30-2004, 12:02 PM   #2
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
So this is with a turboback + Xede as the only performance mods?
jblaine is offline   Reply With Quote
Old 01-30-2004, 02:23 PM   #3
Hummer
Member#: 31892
2004 STi
TXS TBE+XEDE+Gruppe S headers. The headers add a lot of torque.
Old 01-30-2004, 09:38 PM   #4
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
very nice numbers...thanks for the info
bezerk is offline   Reply With Quote
Old 01-30-2004, 11:54 PM   #5
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
Sounds good stuart. At least its making a couple more pounds of boost, that should make the thing pull nice and hard.
-Mike
www.axispowerracing.net
MJU1983 is offline   Reply With Quote
Old 01-31-2004, 02:01 AM   #6
thechoochman28
Member#: 42900
Man i don't miss IL winters at all.
thechoochman28 is offline   Reply With Quote
Old 01-31-2004, 04:01 AM   #7
speed_freak27
Member#: 30798
2001 RS-T Hybrid
2.5>2.2T>257>2.35S
I'm calling BS 3 hours to get home and you didn't push it. Yeah right I know as well as a few other locals how you drive. I can't wait for the track to open up so I can drive your car again.
speed_freak27 is offline   Reply With Quote
Old 02-01-2004, 02:47 AM   #8
STi City
Member#: 43327
so how did they fix the boost map? what kind of numbers are on your boost map?
STi City is offline   Reply With Quote
Old 02-01-2004, 10:43 AM   #9
Hummer
Member#: 31892
2004 STi
PM sent.
FS: Cobb Accessport for 08 sti w/ perrin stage one map tlewis81 NESIC Private Classifieds 2 06-20-2009 07:57 PM
Differences between Cobb Stage 2 maps for 91, 91 and ACN 93 2slow AccessPort 0 02-12-2009 06:04 PM
stage one map thiefdevious Open Source Reflashes 1 10-28-2008 01:09 AM
Is the 2.5 Turbo the same in the STI and Forrester? tchprivat Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-09-2004 06:28 PM
Racing Seat Installation in the STI and Review Triple S STi Forum Archive 15 09-01-2003 10:19 PM
