Welcome to the North American Subaru Impreza Owners Club Saturday January 31, 2015
Old 01-30-2004, 12:44 PM   #1
Hawk296
Member#: 14555
1995 Impreza L
Baja
Default Cam/Crank sensor check
How do I test the cam and crank sensors? What is the proper procedure? thanks.
Hawk296 is offline   Reply With Quote
Old 01-31-2004, 08:49 PM   #2
avk
Member#: 17252
'06 WX8
59E
The manual specifies the resistance of the pick-up coil, but my understanding is that these sensors fail because of cracked solder between the coil wire and the terminal posts so that the problems are intermittent. If you get a trouble code for either one, replace both.
avk is offline   Reply With Quote
Old 02-01-2004, 12:13 PM   #3
atabert
Member#: 45107
1992 Legacy L
Green
Default sensors
ya replace both, they make a kit where you get both sensors and they only cost approx. $40.00
atabert is offline   Reply With Quote
Old 02-01-2004, 02:06 PM   #4
Hawk296
Member#: 14555
1995 Impreza L
Baja
thanks a lot. Yeah I do have replacements, but its an intermittent thing which i think could be cam/crank sensor. I am not getting a CEL though, but thats not saying much.
I just wanted to check them and try and duplicate the situation before i throw parts at it. What value is specified when i check the resistance?
thanks a ton!
Old 02-01-2004, 08:31 PM   #5
avk
Member#: 17252
'06 WX8
59E
The spec'd resistance is 1 to 4 KOhm for both sensors. I did get this reading with a bad cam sensor, but there already was a trouble code.
Old 02-01-2004, 08:42 PM   #6
Hawk296
Member#: 14555
1995 Impreza L
Baja
Excellent! thank you much!
pics of cam/crank sensor locations STIFLYBY_RANGER Newbies & FAQs 2 03-02-2010 12:30 AM
cam crank sensor misfires TyranosaurusWRX Built Motor Discussion 2 08-25-2008 06:03 PM
FS: Crank sensor, Cam Sensor, FPR gren737 Engine/Power/Exhaust 1 07-14-2007 11:39 PM
cam sensor vs. crank sensor vs WTF TyranosaurusWRX Built Motor Discussion 31 08-19-2006 04:42 PM
WRX/STi cam/crank sensors... d00f Engine Management & Tuning 2 09-17-2004 10:59 AM
