Old 01-30-2004, 03:01 PM   #1
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
Default Radiator Fluid and overflow tank sludge
I changed the radiator fluid today and as I filled up the top fill tank I squeezed the upper rad hose like a basting bulb to get all the air out of the system Worked great.
Then I removed the overflow tank to dump the old fluid out of it and to my surpise there was a 2" layer of orange sludge at the very bottom on the overflow tank. And for the early WRX's that had the paint peeling off the inside of the radiator cap tank then you will find quite a bit of peeled paint mixed in the sludge. The sludge is quite remarkable. I wonder where it all came from?
Just FYI is all.
Greg D
gpd323 is offline   Reply With Quote
Old 01-31-2004, 01:10 AM   #2
cvalle-sd
Member#: 420
2001 Cr-V
have you ever put anything but coolant or water in? Stop leak? ever added one brand of coolant to another?
Orange sludge sounds pretty freaky.
cvalle-sd is offline   Reply With Quote
Old 01-31-2004, 09:58 AM   #3
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
It was the stock fluid from the factory. I did add Redline water wetter but that was it. I recall early on that when I checked the rad fluid the upper tank was all orange and this orange stuff was floating on the top of the fluid. I mentioned this years ago when I bought the WRX. Others seemed to experience the same coolant issues to include the paint on the inside of the tank top where the rad cap is peeling off and heading into the coolant passages. I had taken my tank top off and removed what was left of the paint.
The sludge is really weird, I wonder if all the low lying coolant passages and areas are packed with this stuff?
But whan I changed the rad fluid it was clear and not orange discolored.
Greg D.
Old 01-31-2004, 01:51 PM   #4
cvalle-sd
Member#: 420
2001 Cr-V
That's a poser...To be safe, I'd assume that at least some of that stuff is still in the system. An occasional flush is a good idea anyway. I'm about to do it for my ailing EJ25. You could just take it in to a mechanic and have them pump it out, but I'm going cheap, and using that Prestone stuff.
Old 02-01-2004, 10:12 PM   #5
Raptor75104
Member#: 52363
2009 Legacy GT
Ruby Red Pearl
A couple of things on this subject, if I may...
1st - My humble opinion on the orange gunk is that it's sediment from mixing tap water with the coolant (which most everyone does). Why it turns orange? Dunno. Why it settles in your reservoir? Because that's where coolant sits and it has a chance to. It never circulates there. Nasty isn't it? As you may or may not be aware, coolant is sometimes pressured into the reservoir when the system is hot and then sometimes it's sucked out of the reservoir and back into the radiator when the system cools, to sort of "top things off." Your cleaning out your reservoir is an excellent idea if you don't want that crap getting sucked back into the radiator.
2nd - I have seen quite a few times where someone has not maintained their cooling system and, after 80,000 miles, they want a flush. Generally speaking, this is really risky. After this long, not having changed out the fluid, there are deposits in the cooling system that aid in sealing it. Flushing washes all of that out. Leaks will occur as the seals/gaskets have aged and worn. This also holds true for automatic transmissions and laquers that have built up (but that's another post). If coolant changes are performed routinely, then flushes aren't really necessary unless you just want to. But if someone is working on 70,000 miles and hasn't changed their coolant, then draining and refilling is ok, but flushing is not recommended.
Also, with coolant, don't buy into the "extended life" stuff thinking you won't have to change it out as often. Coolant has a shelf life of 18 month and will go a while longer. Why would it last longer under the duress of being in an engine? I'd recommend draining and refilling every two years or 24,000 miles, whichever comes first. 5 years or 150,000 miles is a bunch of hooey. The additives that make coolant what it is have done worn out.
Hope this helps.
Raptor
Raptor75104 is offline   Reply With Quote
Old 02-01-2004, 10:20 PM   #6
Tex-WReX
Member#: 7107
2014 Mustang GT
My 2 cents. I have an 02, and the magical black paint chips. I did my second change today (lots of miles, @ 65k miles ). Lots of sediment and black chips in the resevoir. Takes all of a min to pull it out and give it a good flush. I have always used non-silicate anit freeze and demineralized water. Hopefully, @ the 90k mile change, the sediment will be at a min. I also use Royal Purple -Purple Ice (similar to water wetter). Hope this helps as well.
Tex-WReX is offline   Reply With Quote
Old 02-02-2004, 09:29 AM   #7
gpd323
Member#: 9878
2002 WRX/GTX
WRX Wagon/Mazda GTX
Good ideas and suggestions.
I too only use distilled water and fresh antifreeze.
The sludge was created with the OEM factory fluid which was due for its 1st change. Not any aftermarket fluid.
The paint in the sludge is from the 1st allocation of WRX's that had the painted black cover where the radiator cap is. Later 2002's came w/unpainted covers.
Greg Downing
Old 02-02-2004, 01:32 PM   #8
KanosWRX
Member#: 17904
010 STI
This was talked about a lot in another thread. I actually had the same problem, the paint was coming off the resevoir tank and you could see stuff floating around in there. I took it to a dealer and they replaced it with the 03, non painted resevoir tank under warranty, took about a week for the part to come in, then 1 hour for them to replace it. Now I just need to flush the coolant, will probably do it this spring.
KanosWRX is offline   Reply With Quote
Old 02-03-2004, 05:05 AM   #9
armand1
Member#: 10309
'02 OBS 2-tone!
'95 Montego Miata
Originally posted by gpd323
It was the stock fluid from the factory. I did add Redline water wetter but that was it. ...
Water Wetter (and equivalents) have been associated with some sludging in the overflow tank.
It also helps to keep the overflow tank always up to Full, so the liquid inside doesn't get too concentrated/dried down.
2004 STI Radiator with both fans, overflow tank, lines and mounting - complete OEM Royal Motors Engine/Power/Exhaust 23 04-17-2009 03:06 PM
WTB-radiator top mounts and overflow tank-06 STI toomuch NWIC Private Classifieds 2 09-19-2008 02:38 PM
Aluminum Radiator overflow tank djerickd Private 'Wanted' Classifieds 13 11-24-2007 01:55 AM
what radiator overflow tank to use with Hyperflow FMIC ? billy boi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-21-2005 07:08 PM
Small radiator overflow tank american GC8 ? bigbird Normally Aspirated with bolt-on Forced Induction Powertrain 8 05-02-2003 01:58 PM
