Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Old 01-30-2004, 03:05 PM   #1
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
Default battery recommendations
The battery on my 95 Legacy went bad, I thought it was going to be the alternator but it turned out to be just the battery. They want $80 for a stock battery and another $30 to install it which I don't think is a very good deal.
So, keeping in mind that I need my car soon, therefore I need to get a battery locally. Any recommendations? Probably pick one up at NTB or someplace and have my friend drive me to the garage.
kami333 is offline   Reply With Quote
Old 01-30-2004, 03:14 PM   #2
subawang
Member#: 17515
2007 Legacy GT
Brilliant Silver Metallic
I got a diehard silver at sears for ~$80 including installation. I'm in illinois where its -5 degrees and my subie starts right up. I have a MY00 RS.
subawang is offline   Reply With Quote
Old 01-30-2004, 03:22 PM   #3
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
How hard is it to change the battery anyways? I just need to take the battery posts off, take the nuts off the battery tiedown, then swap it?
Old 01-30-2004, 04:00 PM   #4
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Pretty much...there's nothing deceptive about it.
Zola is offline   Reply With Quote
Old 01-30-2004, 04:24 PM   #5
LotusDriftx
Member#: 48528
I just spent 2 days online searching for 'the battery'. Nothing conclusive out there anywhere.
Just pick up the mid grade battery from autozone or sears. There was one battery review from consumer ________, that picked a costco battery as its favorite.
I got a few people telling me to get optima but there is no way I could justify the 70 extra dollars...unless you had like a million electronics in your car, than the yellow top might be good for you.
LotusDriftx is offline   Reply With Quote
Old 01-30-2004, 06:42 PM   #6
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
Ended up going for the Optima redtop, considered the yellowtop but I read that they would lose their charge after 2weeks? Not the battery for me. I have a carpc + plus screens and other stuff so I decided that it might be worth it to spend a few bucks extra. Working like a charm now, the headlights actually light up the road!
Old 02-01-2004, 03:08 PM   #7
Snitt
Member#: 36361
2004 WRX Cobb Stg II
WR Blue
I thought I was crazy last night when I noticed that my headlights seemed brighter after installing my red top. Maybe I'm not...
Snitt is offline   Reply With Quote
Old 02-01-2004, 05:13 PM   #8
FortyTwo
Member#: 39738
2003 Impreza WRX
Midnight Black Pearl
I think the general attitude is that Optima Yellow top is the best, but require extensions. Red tops can be had in a reverse configuration and are easy to install. You should be able to pick up both locally.
Also, 30 BUCKS FOR INSTALL?!? Haven't you see the autozone commercial where the kindergarten teacher replaces her battery?
FortyTwo is offline   Reply With Quote
Old 02-02-2004, 01:22 AM   #9
hawksoob
Member#: 51978
1996 Legacy Outback
Red
Most places I see, Autozone, Advance, etc, offer free installation. My understanding is they do this to encourage return of the old batteries for recycling. If more people did it themselves (easy to do, anyway, as mentioned above) many may not be as likely to make their way to the proper recycling facility to dispose of the spent battery.
hawksoob is offline   Reply With Quote
Old 02-02-2004, 08:27 AM   #10
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
I have the old battery in the trunk, I return it and get my $5 deposit back.
FortyTwo: What do you mean by reverse configuration? I just got the one they had at PepBoys and the cables were a bit of a reach, do they have one that is easier to install? The cable leading to the fuse box is a little strained at the moment, if there is a better configuration I'd like to know.
Old 02-02-2004, 09:38 AM   #11
JIN
Member#: 27731
I would recommend Optima Redtop man. Think there is one that is a direct replacement for our cars.
Jin
JIN is offline   Reply With Quote
Old 02-02-2004, 12:26 PM   #12
FortyTwo
Member#: 39738
2003 Impreza WRX
The Group 35 Red top Optima has the terminals in the OEM location. It is often called the "reverse" config.
Old 02-02-2004, 09:17 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The one sold at Pep Boys is the 35/75 "universal" model with side and top terminals. I bought this one some time back and made it work with a longer starter cable which was cheap and fairly easy to do. However there is now a 35 Red available with post terminals only that are in the proper location, and it can be installed directly in place of the OEM battery with no modifications. It is available from online vendors and may be referred to as a "reverse" 35 or just a 35. A look at the picture should confirm it is the correct model as the terminals will be at the outside corners of the battery rather than near the center as on the 35/75.
New Battery recommendation!! tbadhesha Electrical & Lighting 1 05-29-2008 03:14 PM
battery recommendation Hokie-wrx wagon Mid Atlantic Impreza Club -- MAIC 17 12-19-2007 07:03 PM
Battery Recommendations infamousone New England Impreza Club Forum -- NESIC 13 06-12-2006 11:00 AM
Battery Recommendations Loki Electrical & Lighting 8 01-27-2004 03:39 PM
Lightweight battery recommendations needed boxerT Electrical & Lighting 7 07-13-2003 11:39 PM
