Old 01-30-2004, 05:08 PM   #1
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Default Is there a difference from the Stock STI radio and a Stock 02-04 WRX radio?
Was told that the deck for the STI was only for the STI and didn't see how this could be true as the dashes are for the most part basically the same, if not the same.
I am going for the all stock just for simplicity and can get a 02-03 changer for about 250 where a 04 STI one is like 700.
roybfr is offline   Reply With Quote
Old 01-30-2004, 08:17 PM   #2
2003forcefed
Member#: 28643
2007 STi
Urban Grey Metallic
I think there is no difference between the 04 WRX and STi.
There is a difference between the 02-03 and 04's. Only faceplate color and illumination. I could be wrong though. I just bought a 04 deck for my STi...Hope it goes in with no hassle...Good luck
2003forcefed is offline   Reply With Quote
Old 01-30-2004, 08:30 PM   #3
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Well from my experiance with the 02 dash the 04 Sti comes apart the same, and the din pocket looks the same, I guess I will find out when I take the dash apart to put in my radio.
Old 01-30-2004, 08:33 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It's basically the same POS. The main difference aside from the color is that the 04s have the amplified rear window antenna which gets powered from the radio, I'm not positive that the earlier units supply the necessary switched power output. Even if they don't you can always connect accessory 12V to the antenna power wire in the harness.
Old 01-30-2004, 08:38 PM   #5
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
So does this antenna power issue need to be taken into consideration when installing an after market deck.
Old 01-31-2004, 12:16 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
On an 04 with the amplified antenna you have to be sure to connect the switched power lead, usually labeled "power antenna", from the new HU harness to the factory wiring. If you use a standard adapter harness the connection should be made automatically but you want to be sure it is, or your radio reception will suck.
Is there a difference from 02 front brake setup to 03? FairladyZ Newbies & FAQs 5 05-06-2010 10:00 PM
Is there a difference between the new WRX 2.5l block and the STI shortblock? keaniegenie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 09-20-2005 01:21 AM
Pics of 05 sti....is there a difference from 04? wrichiex_sti Member's Car Gallery 7 05-25-2004 04:35 PM
is there any difference from the wrx and sti head flow charactaristics STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-06-2002 12:06 PM
