Old 01-30-2004, 06:20 PM   #1
GT2RS
Member#: 1077
Default Defi Boost Gauge installed-Low Readings?
I just installed a boost gauge for the STi...
52mm Defi D-Gauge
Now i'm wondering if the readings are correct...
Engine off: 0
At idle/cruise: -20 in Hg
Max boost: 10 PSi only!
Triple checked the installation and everything is according to the instruction.
GT2RS is offline   Reply With Quote
Old 01-30-2004, 10:59 PM   #2
GT2RS
Member#: 1077
Fixed!
Old 01-31-2004, 06:02 AM   #3
asianboy101
Visiting NASIOC Timeout
Member#: 46373
2004 subaru sti
blue
i have the same thing. i just picked it up. have not installed in my sti yet. could you tell me more what happened and what was your cure for this problem.
asianboy101 is offline   Reply With Quote
Old 01-31-2004, 11:52 PM   #4
GT2RS
Member#: 1077
Replaced the cheap Defi supplied hose. It was packaged so tightly in a box and came out all deformed! Other than that the gauge looks awesome specially at night and very accurate!
Old 02-05-2004, 10:00 PM   #5
cann
Member#: 8618
what's your max boost?
cann is offline   Reply With Quote
Old 02-06-2004, 09:16 PM   #6
bunni
Member#: 42524
Are all the D-Gauges mechanical?
bunni is offline   Reply With Quote
Old 02-06-2004, 10:07 PM   #7
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
No they are not. All of mine are electrical (Oil pres, oil temp, tranny oil temp, coolant temp, fuel pres and EGT).
AJ
AJ711 is offline   Reply With Quote
defi boost gauge install mardigras Interior & Exterior Modification 2 07-09-2008 12:57 AM
Questions: Defi boost gauge install 03'WRXtreme Interior & Exterior Modification 4 05-08-2008 02:34 PM
Defi Boost gauge install Venividivichi Electrical & Lighting 2 04-21-2008 12:20 AM
defi boost gauges install jlam86 Electrical & Lighting 1 12-13-2006 06:02 AM
DEFI boost gauge install help? elsanto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-07-2003 07:29 PM
