Old 01-31-2004, 01:07 AM   #1
94GF8
Member#: 43132
1994 WRX Wagon
Grocery Getter my arse...
Default What's wrong with my Tach?
I've got a 1994 WRX Wagon,
At first it seemed like the Tach couldn't keep up with the engine when I really got on the throttle. Now it seems like when I shift the tach only drops half as much as it should so that when I stop it is saying 1800rpm. I can tell by the sound that my WRX isn't idleing at 1800. What's going on here?
Until I get this fixed I don't wanna push my car too hard, and we all know how much WRXs like to be pushed...
-Eric
94GF8 is offline   Reply With Quote
Old 01-31-2004, 03:41 AM   #2
SlaminSuby25RS
Member#: 20425
99 2.5RS swapped
05 Legacy GT
have you ever taken apart the dash, it could be dirty/ sticky. Just a thought.
SlaminSuby25RS is offline   Reply With Quote
Old 01-31-2004, 08:43 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You might want to try posting on one of the boards in Europe where they are familiar with your car. This is a North American board and we never had a 94 WRX here so although we may be able to offer general advice, we don't have specific info or experience on your car.
Old 01-31-2004, 04:44 PM   #4
94GF8
Member#: 43132
1994 WRX Wagon
Default General Advice
From what I've seen, mechanically and electronically the majority of the WRX stayed the same. True there are small differences for instance, the bypass valve comes off of the TMIC now. What I was hoping is that someone else had experienced this.
No I've never taken apart the dash. Maybe I should
It happened again last night, I was pulling hard in 3rd gear, and the tach stopped at about 3800, then right before I shifted it jumped up to 6500.
Does anyone know of any European WRX boards?
Thanks,
-Eric
Old 01-31-2004, 05:19 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You might try Scoobynet, it's UK-based.
http://www.scoobynet.co.uk/
Old 01-31-2004, 07:41 PM   #6
avk
Member#: 17252
'06 WX8
59E
The tach must be of the same design as 1993-96 US-Canada tach. First things to check, in my opinion, would be the cluster harness connections, and the screws holding the tach to the cluster housing. Those screws are what connects the tach to the cluster circuit board, so they must be tight.
avk is offline   Reply With Quote
Old 02-03-2004, 05:29 AM   #7
94GF8
Member#: 43132
1994 WRX Wagon
Well, Scoobynet hasn't produced even a response, let alone an answer so I'm gonna try checking the connections inside the dash. I would also like to try checking the source of the signal. Does anyone know where the signal comes from? A friend here told me that he thought it came off of the tranny. I was thinking it was more likely that it cam from the Ignition somwhere or else the cam or crank angle sensors.
Any Clues?
Thanks,
-Eric
Old 02-03-2004, 10:06 PM   #8
avk
Member#: 17252
'06 WX8
59E
The signal is sent by the ECU. But that doesn't really matter as long as you're testing it at the cluster (you'd need either an oscilloscope or a known good tach). Actually, the conductors on the board on the back are marked.
Old 02-13-2004, 04:39 AM   #9
94GF8
Member#: 43132
1994 WRX Wagon
ScoobyNet said that my problem is the Battery, and that the fix is to replace the Battery.
This doesn't make sense to me. Can someone please explain it?
-Eric
Old 02-15-2004, 05:16 AM   #10
94GF8
Member#: 43132
1994 WRX Wagon
In the words of the immortal Flanders "Bump-Diddley-Ump"
What's wrong with my foot? Diagnose my foot pain beachbum Off-Topic 7 05-09-2006 11:00 PM
What effect would a broken Zener Diode have? And, what's wrong with my car! Eric SS Normally Aspirated with bolt-on Forced Induction Powertrain 14 11-17-2001 12:20 AM
('93-'01) Pleasae help. What's wrong with my math? Eric SS Impreza Forum 10 10-24-2001 06:00 PM
What's wrong with my system in my WRX? WRXThis Car Audio, Video & Security 7 10-23-2001 12:52 PM
What's wrong with my alarm? garface Car Audio, Video & Security 3 06-28-2001 05:44 PM
