Old 01-31-2004, 02:52 AM   #1
tEkkGOD
Member#: 10110
Default My right headlight keeps turning off.
i replaced my bulbs when the right headlight went out.
well i drove the car at night and it went out again!
then i drove it some more and it came back on!
then i drove it back home and the right passenger one was out again!
help!
what can be wrong?
tEkkGOD is offline   Reply With Quote
Old 01-31-2004, 03:37 AM   #2
SlaminSuby25RS
Member#: 20425
99 2.5RS swapped
05 Legacy GT
dirty/melted harness
SlaminSuby25RS is offline   Reply With Quote
Old 01-31-2004, 03:45 AM   #3
FletchMY98
Member#: 6395
2006 WRX STI
Steel Grey Metallic
tEkk,
* Make sure the connection is pushed all the onto the bulb.
* Make sure all your ground wires are tight and corrosion free.
Are you using stock wattage bulbs...??? Higher wattage bulbs can cause a bunch of problems. Melted wires, melted connectors & melted reflectors.
Regards,
Chris
FletchMY98 is offline   Reply With Quote
Old 01-31-2004, 04:36 AM   #4
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
didnt i already diagnose this problem for you yeah i would replace the connectors.....
ATX25RS is offline   Reply With Quote
Old 12-22-2009, 05:46 AM   #5
sirmasterdeck
Member#: 199807
2006 STI
World Rally Blue
SUUPPPPEEEER ancient thread but I am having exact identical problem and I checked connectors with no results. I notice that if I flip the headlight switch on and off a few times eventually the right headlight will just seem to magically decide to work. Any other ideas? Nothing else electrical goes out with it, just that one damn headlight every once in a while. I notice it happens more when I'm slowing to a stop in first gear. Any input would be greatly appreciated!
sirmasterdeck is offline   Reply With Quote
Old 12-22-2009, 06:45 AM   #6
GARGOYLE
Member#: 178918
Same here.
I engage/disengage the hand brake,it goes on...few minutes later,flickers out.
I can not find the cause yet.
GARGOYLE is offline   Reply With Quote
Old 12-22-2009, 11:02 AM   #7
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Most of the time this kind of trouble is located at the connection to the bulb. You need to use a test light at least to check for voltage at that point.
Old 12-23-2009, 12:39 AM   #8
sirmasterdeck
Member#: 199807
2006 STI
World Rally Blue
I noticed that when I look directly at the front of the car the bulbs seem to be different colors. One is slightly blue while the other is a more typical yellowish bulb color, I'm thinking maybe perhaps the previous owner messed with the bulbs and maybe changed one and not the other? Or perhaps the car was in some kind of accident where one bulb or headlight housing was replaced? Could an electrical problem cause the bulb to become discolored? If not maybe an unsuitable bulb was used to replace the stock one? Hmm it seems like I have some diagnosing to do. Has anyone else experienced similar problems using a different bulb for the headlights?
Old 12-23-2009, 11:05 AM   #9
Cougar4
Member#: 53443
Winestone
It really doesn't matter what the color (color temperature range) of the bulb is. If it doesn't have a good power connection you got nut'n or a dim light depending on the connection condition.
Old 12-23-2009, 09:26 PM   #10
sirmasterdeck
Member#: 199807
2006 STI
World Rally Blue
Still no luck. I ordered a new bulb to see if that would remedy the problem I've noticed that the only way to get it to turn on is by turning the headlight on and off with the handbreak switch. If I use the headlight switch next to the steering wheel it doesn't do anything not sure why this would make a differance but it may indicate some kid of wiring problem between the wiring from the handbreak? I don't know if that could even be a possibliry, this is really puzzling me any idea why only messing with the hand break would cause it to flicker back On and not the steering column switch?
Old 12-24-2009, 10:36 AM   #11
b00st3d
Member#: 9891
2015 RC-F
Ultra White
the handbrake IIRC disables the daytime running light. so when you engage/disengage the handbrake, it is engaging and disengaging the DRL, which is why the lights turn on and off.
b00st3d is offline   Reply With Quote
Old 12-24-2009, 11:05 AM   #12
Cougar4
Member#: 53443
Winestone
B00st3d is correct. The DRL circuit adds a resistor to the head light low beam circuit to reduce the current through the light and dim the lighting slightly. The trouble may be in the switching for the DRL circuit.
My F90BT Navigation Keeps Turning On and Off While Driving wrxgeneration Car Audio, Video & Security 6 12-31-2008 04:12 PM
Need help! my headlight won't turn off! nycsubaruwrx Electrical & Lighting 4 11-27-2007 06:21 PM
My headlights won't turn off!! Please help!! Carlito2002WGN Newbies & FAQs 15 05-23-2007 04:08 PM
Car Keeps Turning Off!! Robert E Service & Maintenance 3 12-25-2003 05:01 PM
Computer keeps turning off after Windows load screen? garface Off-Topic 20 08-27-2002 11:12 AM
