Old 01-31-2004, 05:35 AM   #1
it8ezbngrn
Member#: 35590
Default Harness available for headlamp tilting motors?
Is there a PnP harness available for the tilting motors on the JDm lights? Or at least a good thread on it?
it8ezbngrn is offline   Reply With Quote
Old 01-31-2004, 01:13 PM   #2
speedevangelist
Member#: 47826
2002 WRX wagon
I have the same question... got the lights and switch, now I need the wires.
speedevangelist is offline   Reply With Quote
Old 01-31-2004, 01:16 PM   #3
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Search this forum for posts by a user named wagons_ho! He is located in Toronto and probably has what you need.
Joel
Zola is offline   Reply With Quote
Old 01-31-2004, 01:25 PM   #4
speedevangelist
Member#: 47826
2002 WRX wagon
Old 01-31-2004, 03:25 PM   #5
wagons_ho!
Member#: 16574
Default It's true, baby
I make harnesses using the opposite plugs of what's on the lights.
Others make harnesses, but you have to cut/splice/crimp a different plug on the light. What happens if you have to change lights for any reason?
I build adapter "thingies" for a living at work - interfacing old equipment with new systems, and vice versa. If it was to be all hardwired, a replacement would have to be hardwired, but with an adapter harness in the middle, you can change what you want when you want.
My harnesses come with plugs for the motors, a circuit adder that provides power from the fusebox, and a ground lug to hook it up to ground. My 13yo daughter installed it in the family TS in 15 minutes - will be longer if you have big hands, an intercooler or a strut bar.
I'm into this for 1700 for connectors - all to make my lights move up and down with a full load.
Contact me via EMAIL.
I'm away from Toronto for a bit, and have NO access to PM over the corporate network.
Thanks.
wagons_ho! is offline   Reply With Quote
Old 01-31-2004, 05:16 PM   #6
it8ezbngrn
Member#: 35590
I'll keep you in mind when I get my set. Hopefully next week.
Old 02-03-2004, 10:07 PM   #7
wagons_ho!
Member#: 16574
Default Harnesses
Let me know... I'm away from home and instead of sleep at night I can build harnesses...
Old 02-05-2004, 01:00 AM   #8
2K4 STI
Member#: 36367
87 Old Skool RX
wagons ho can you make the leveling motor harness for the 04 sti hid lights.or is it the same as the jdm style.i did a search but couldnt come up with anything.and how much US currency.
thanks,scott
2K4 STI is offline   Reply With Quote
Old 02-06-2004, 02:19 PM   #9
wagons_ho!
Member#: 16574
Default 04STi HID
I won't build what I can't test, because that puts us all in a state of "it worked at my shop, why won't it work in your car". And in Canada we don't have HID on the STi.
If someone sends me a light, I can build it, and certify it to be correct, or if someone wants to send me a pic of the light connector and the wiring, we can make it work from a distance.
12 more sleeps and on the way home!
Geo
Old 02-06-2004, 08:13 PM   #10
skivvie
Member#: 29719
'06 WRX Wagon
http://forums.nasioc.com/forums/show...hreadid=439120
that thread contains pics i took of the sockets for the '04 STi HIDs
skivvie is offline   Reply With Quote
Old 02-07-2004, 12:24 PM   #11
wagons_ho!
Member#: 16574
Levellers for the 2004 STi motors use the same plug as the 2003. I need to confirm the wiring on those motors.
OmniMount - Power55 Tilting Motorized Wall Mount for 32" - 55" TVs - BNIB! rubrduk SCIC Private Classifieds 1 09-20-2009 08:11 PM
OmniMount - Power55 Tilting Motorized Wall Mount for 32" - 55" TVs - BNIB! rubrduk Non-Subaru Stuff 4 05-01-2009 04:59 AM
OmniMount - Power55 Tilting Motorized Wall Mount for 37" - 55" Flat-Panel TVs rubrduk SCIC Private Classifieds 2 02-12-2009 10:16 AM
Are Pre-Fabbed PnP Harnesses available for Hydra>EJ20G Leggy Style? DSM_Outback Other Engine Management 2 05-15-2007 03:20 AM
jdm headlamp, leveling motor wiring instructions toulakid Electrical & Lighting 2 03-15-2007 08:56 PM
