Old 01-31-2004, 10:49 AM   #1
minh
Member#: 6792
02 M3, 05 OB XT
Default splash guard and oil change...
anybody have a pic of which bolts to remove for the splash guard, or an accurate description of which ones to remove? I could probably figure it out while I'm under the car, but I would end up removing a lot of bolts that I wouldn't have to, and I would be grateful for the time saved too! last time I changed the oil and filter, I left it on, and it was a PITA to clean the engine-side of the splash guard when it was still on the car (a bunch of oil leaked on it obviously). Thanks!
minh is offline   Reply With Quote
Old 01-31-2004, 12:17 PM   #2
03WRXMA
Member#: 35081
2012 WRX
There are 3 greenish 12mm bolts on towards the front of the car, the also have a phillips head on them; Plus two clips on either side of it, the kind where you pull the center out, then the whole clip out.
03WRXMA is offline   Reply With Quote
Old 01-31-2004, 12:32 PM   #3
grindMARC
Member#: 23547
02 WRX Wagon
Mersoydes 300SDL
I've managed to change my oil every time without having to remove the splash guard. I use one of those parrot beak looking filter wrenches. There's only one spot where I can get a good bite on the filter, so it takes a bit more effort than if the guard was off. Overall though, I'm sure its faster.
grindMARC is offline   Reply With Quote
Old 01-31-2004, 12:38 PM   #4
minh
Member#: 6792
02 M3, 05 OB XT
thanks.
Old 01-31-2004, 01:22 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If I am not mistaken, the splash guard on the '04 is different than the 02/03 - it actually goes under the filter, making removal sort of necessary. I wonder if you could retrofit the 02/03 setup onto an 04 - I can change my oil without getting a drop on the splash guard (also - you really shouldn't need a filter wrench unless the filter was put on too tight)
Old 01-31-2004, 02:06 PM   #6
minh
Member#: 6792
02 M3, 05 OB XT
I have an 04 and it does completely cover the filter...
Old 01-31-2004, 02:43 PM   #7
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Hmm, I wonder why they changed the design for '04? My '03 definitely doesn't cover the filter. I wonder if they did it for aero reasons?
Can any '04 owners take a pic of the splash guard?
drees is offline   Reply With Quote
Old 01-31-2004, 04:27 PM   #8
devin
Member#: 17196
06 Accord
i just cut a hole in the bottom of my splash guard so i don't have to take it off every time i change the oil
devin is offline   Reply With Quote
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! Unabomber Service & Maintenance 741 05-13-2013 09:57 AM
Integrated OEM Splash Guard and Rally Armor Mud Flaps ChronicHerb Member's Car Gallery 17 09-24-2009 02:19 AM
brand new GC aero splash guards and other misc parts Jewbaru 1993 - 2001 Impreza Specific Parts 8 06-05-2009 11:10 AM
WTB Factory Splash Guard and hardware goover Private 'Wanted' Classifieds 0 01-26-2008 07:02 PM
Splash guards and rear bumper covers on sale subaruwrxparts.com Accessories & Misc 0 12-06-2007 04:40 PM
Message Board Statistics All times are GMT -4. The time now is 08:45 AM.
