Old 02-07-2004, 07:35 PM   #1
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Default 2.5rs swap questions???
I have been considering a engine swap for my 98rs for awhile now and hoped someone could answer some quesions.
First if I get a JDM engine, what if I need replacement parts, are the easy to get, or am I ordering from Japan?
I always thought cars in Japan used a higher octain fuel. IS 92 ok for these engines?
I see all these V7, V8 engines for sale. what are the differences? would I need to swap the transmission and other drivetrain parts? I appreciate as much info as possible.
sti27 is offline   Reply With Quote
Old 02-07-2004, 11:16 PM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
jdm parts are kinda hrad to find, helps if you know japanese.
92 fuel will work but is not the best thing. if you live in a place the sells race fuel you should use it. if you get the ecu flashed 92 should be no prob.
i may be wrong but v8 sti is twin scroll, v7 inst. but both are great motors. check out this site
http://www.northursalia.com/t...y/history.html
hope this helps
RS_to_WRX_swap is offline   Reply With Quote
Old 02-07-2004, 11:30 PM   #3
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
Ok first off you can get parts for the car in UK or australia and it is not hard to get them just takes a while to ship here. Also are cheaper to buy from australia with the exchange rate. The octane issue is only a problem if you are running JDM ECU in that case there are chips you can get from australia for 200$ shipped to add boost and tune for the 91 octane and so forth. Contact me for more info!
AWJunkies is offline   Reply With Quote
WRX Motor Swap w/2.5RS drivetrain Question. mykrrrr Subaru Conversions 155 05-06-2015 10:28 PM
2.5RS Swapped! 2.5RS parts & Leftovers from JDM WRX Clip moss Private 'For Sale' Classifieds 111 08-18-2006 09:43 AM
Will 02 2.5RS headers fit a MY00 2.5RS swap? 83Rabbit Normally Aspirated Powertrain 3 05-31-2006 09:19 AM
'98 2.5RS - swap in '02 WRX motor a/ Tec II alfriedesq Normally Aspirated with bolt-on Forced Induction Powertrain 3 05-19-2002 02:41 AM
newbie with a question...2.5rs turbo question...which ones???? QCK HNDA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-03-2001 08:10 PM
