Old 01-31-2004, 03:26 PM   #1
hrb93
Member#: 39050
Default Unichip Install "HELP"
How do you make the metal plate (cover) fit back over the Unichip and EMI adapter, when it's piggy backed on top of the original computer?
Pictures?
Detailed Instructions?
Anything?
I got the bottom 2 bolts back on, but the plate (cover) is touching the Unichip and EMI, with a bit of pressure?
Equipment needed etc.
Thankyou.
hrb93 is offline   Reply With Quote
Old 01-31-2004, 03:40 PM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
The turboXS unichip and Utec comes with these brass riser type things to raise the kick plate so it's resting on those instead of the ECU.
Don't know about Vishnu though...
MAD REX is offline   Reply With Quote
AVC-R and Unichip Installed Drjosh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-04-2002 06:17 PM
UNIchip installation questions... BuickturboV6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-23-2001 08:35 PM
More exhaust after Unichip install? K-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-20-2001 09:55 PM
PE1820, sti injectors, supra fuel pump and turboxs unichip install nmyeti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 43 10-31-2001 11:10 AM
Finally got the unichip installed with the new map RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 10-19-2001 10:50 PM
