Old 01-31-2004, 04:35 PM   #1
tobin73
Member#: 28673
1997 Impreza Outback
Acadia Green Metallic
Default Starter grinding after start - replace?
My starter grinds for 2 seconds after startup. Is there any way to fix this without buying a new starter? The battery connectors are clean and the battery shows 12 volts and 14 volts when running so it's good.
tobin73 is offline   Reply With Quote
Old 01-31-2004, 07:12 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
sounds like the starter is hanging up and staying engaged, so reall way around it than replacing or rebuilding the starter, if that is the case.
Jay
Old 01-31-2004, 11:12 PM   #3
PRIOR
Member#: 27524
95 Impreza L awd
2.5 swap & only 2400lbs
i had this same exact problem for the last year in my car, and just 2 weeks ago was when the starter went out... i just replaced mine since i got it for pretty much nothing.
let me tell you though, jump starting the car with the clutch for a week while the starter was bad was not fun...
PRIOR is offline   Reply With Quote
Old 02-01-2004, 03:24 PM   #4
supermoose
Visiting NASIOC Timeout
Member#: 9093
1995 RHD STi RA Ver2
swap starr
you can get a starter for $45 bux. j-yard take you 1/2 hour to swap out. a new reman one is only $100 or so. if you need help, im local and can teach you how to do it. im introy
h
supermoose is offline   Reply With Quote
Starter grinds after start rick-l Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-23-2010 02:58 PM
Car won't start after engine replacement... rickeolis AccessPort 4 08-07-2007 10:47 PM
Starter grinding after start - replace? tobin73 Service & Maintenance 1 01-31-2004 05:25 PM
