Notices
Old 01-31-2004, 04:36 PM   #1
tobin73
Member#: 28673
1997 Impreza Outback
Acadia Green Metallic
Default Starter grinding after start - replace?
My starter grinds for 2 seconds after startup. Is there any way to fix this without buying a new starter? The battery connectors are clean and the battery shows 12 volts and 14 volts when running so it's good.
tobin73 is offline   Reply With Quote
Old 01-31-2004, 05:25 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It sounds like it's sticking internally and not releasing the drive gear from the flywheel. It would have to be removed from the car and taken apart to see if it can be repaired, for the amount of labor and time involved to mess with it you're probably better off getting a new or rebuilt starter. Chances are if you are able to fix it for now the problem will come back eventually and you'll end up replacing it anyway.
Starter grinds after start rick-l Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 01-23-2010 02:58 PM
Car won't start after engine replacement... rickeolis AccessPort 4 08-07-2007 10:47 PM
Starter grinding after start - replace? tobin73 Normally Aspirated Powertrain 3 02-01-2004 03:24 PM
